je piston compression
Old Jun 11, 2003 | 10:30 PM
h22squeaker's Avatar
Default je piston compression
i was wondering if anyone knows how much of a difference the 11.5:1 je's will perform compared to the stock compression 10.0:1. i plan on running a small shot of nos, like 75 shot and am trying to decide between the two compression ratios. ive talked to je and they suggest the 10.0:1's but i want the 11.5's. they say no nos with the 11.5's. i figure theyre forged and i was running a 75 shot on the stock cast pistons and didnt have any problems so.......just seeing what anyone thought or if anyone has the 11.5's. wana know how much more power on street they have then the 10.0's. without the nos that is.
Old Jun 11, 2003 | 11:29 PM
PrecisionH23a's Avatar
Default Re: je piston compression (h22squeaker)
1 compression point is good for about 10whp. If you run nitrous, the lower the compression the better. Sure you can run nitrous with 11.5:1 on pump gas, if you want to melt your pistons. 10:1 is a good safe compression to stay with if i were you. I also hope you know about sleeving your block as well if you run JE's.
Old Jun 12, 2003 | 07:54 AM
DLB1994's Avatar
Default Re: je piston compression (GudeH23a)
i ran a 100shot on my civic with 12.2:1comp ,i would go atleast go 12:1 with only a 75shot
Old Jun 12, 2003 | 11:34 AM
Default Re: je piston compression (DLB1994)
you have larger ***** then i do.
Old Jun 12, 2003 | 12:01 PM
BlackPrelude93's Avatar
yeah, your crazy, i'd never run compression that high with n02
Old Jun 12, 2003 | 12:04 PM
Greyout's Avatar
Default Re: (BlackPrelude93)
NOS?! I'VE SEEN THE WAY YOU DRIVE! NOS ISN'T FOR AMATUERS!
mcln594
Nov 11, 2007 08:52 PM
ls-v*2
Feb 28, 2007 02:52 PM
boosted k20
Jul 26, 2005 07:46 PM
zilverz
Nov 25, 2002 09:49 AM
lsteggy
Nov 6, 2002 09:40 AM
