Type-S STB
Old Jun 9, 2003 | 07:39 AM
LowFlyin''s Avatar
Default Type-S STB
I finally got around to installing this Saturday. This bar doesn't bolt to studs on the strut assembly, but in 2 pre-drilled (on each side) holes closer to the firewall (still on the strut tower). I had to drop the strut assembly as the base was partially blocking the holes. I was a little leary of that, at first, but after I got into it, it only took about 30 minutes. I had to bend a bracket for one of the connectors on the cruise control to get it out of the way of the STB. This is a cheap mod...on my stock suspension I noticed that it helped quite a bit on high load/high speed cornering. It also improved the response in the steering wheel. I would highly recommend doing at least a STB if not the Type-S bar.
Chris
Old Jun 9, 2003 | 11:16 AM
jji106's Avatar
Default Re: Type-S STB (LowFlyin')
If you get the Mugen or Tein suspensions, they already have the bolts that stick up through those holes as a part of the top mounting bracket.
I think you may need the pillow-ball mounts with the Tein suspension, but I'm not sure.
I've got the Type S STB and Mugen suspension. They are not on the car yet, but they will be in a few weeks! I can't wait!
Good choice on the STB, it's subtle and made by Honda too!
Old Jun 10, 2003 | 09:04 AM
LowFlyin''s Avatar
Did you notice a difference with the Type-S air box?
Old Jun 12, 2003 | 10:50 AM
jji106's Avatar
Default Re: (LowFlyin')
I guess so!
It felt like it pulled more off the line and the transition at the VTEC crossover point was smoother!
90_EX_Civic
13
Apr 11, 2010 05:47 AM
satsilprelude
Apr 1, 2006 08:22 AM
BB6racer
Mar 8, 2006 04:41 PM
BNavZ
13
Feb 17, 2004 11:10 AM
ryan12321
18
Nov 5, 2002 12:04 PM
