help with clutch
Old Jun 12, 2003 | 05:18 PM
knightlude's Avatar
Default help with clutch
For some reason, my clutch won't pop back up. I really need help.
Old Jun 12, 2003 | 05:20 PM
ludeR917's Avatar
Default Re: help with clutch (knightlude)
you probably need a new clutch.
Old Jun 12, 2003 | 05:21 PM
knightlude's Avatar
This clutch is not even 3 months old. I was trying to change the fluid but for some reason it's just down and won't pop back up
Old Jun 13, 2003 | 05:01 AM
Prelude Vtec 23's Avatar
Default Re: (knightlude)
You do not need a new clutch. You have air in your lines and have to bleed your clutch. Just bleed it and you will be fine.
Old Jun 13, 2003 | 05:29 AM
prelude1897's Avatar
Default Re: (Prelude Vtec 23)
You may need to bleed your clutch line or you may need a new master/slave cylinders
Old Jun 13, 2003 | 10:19 AM
knightlude's Avatar
Do I keep on pumping the clutch and bleed it at the same time? What if all the fluid is gone when I bleed it. How do I get the air out of the lines with no fluid? I don't really know..
thanks
Old Jun 13, 2003 | 10:30 AM
prelittlelude's Avatar
there is a bleed screw on the slave cylinder, and there is a resivior connected to the master cylinder, you make sure that you keep the resivior close to full , and open the bleed screew as someone else pushes the clutch pedal down, then close the bleed screw while the cluch pedal is still DOWN, then let the clutch up and repeat unitl you think the clutch has no more air, and make sure to keep the resivior filled
yes i know i fucked my spelling but oh well
Old Jun 13, 2003 | 05:24 PM
knightlude's Avatar
thanks
alx_90ef
Jun 14, 2009 01:30 PM
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
Lb1atx
Sep 7, 2007 05:16 AM
integra81
Sep 10, 2003 10:39 AM
