HELP AC is not working?!!!!
Old Jun 7, 2003 | 03:39 PM
Token Blk Guy's Avatar
So what I drive a Volvo
Default HELP AC is not working?!!!!
Well i it happens to be one of the hottest days in Nor Cal and i went to turn on my AC and i got nothing. NO cold air just hot air. So i get to the house And i am checking for fuses for the AC-- i dont see any. Reset the ECU still nothing. So i turn the car on let it run for 3 min and i hit the AC button.
Well u know how when you turn AC on the car hesitiates and you can here the compressor, well i got nothing and my cooling fans are not running. WTF could be the problem!! This is on a 5th gen!!
Token!!
Old Jun 7, 2003 | 05:11 PM
RacingLude's Avatar
I had an AC problem last year that took about a month and 3 mechanics to fix. I replaced everything and it still would only work part of the time and then stop for no reason. It ended up being the dash controls. $50 later the thrid mechanic reweld the points and fix it.
Old Jun 7, 2003 | 05:15 PM
smslude's Avatar
Default Re: HELP AC is not working?!!!! (Token Blk Guy)
It could be freeon (spelling), maybe your compressor? Other than that i dont know.
Old Jun 7, 2003 | 06:25 PM
hagrid's Avatar
Default Re: HELP AC is not working?!!!! (smslude)
the prelude i'm gonna get is having the same problem. i think the compressor is messed up. and what buttons do you have to press to get a/c to come out of the front middle vents? i tried the ones with the air blowing in your face, in your face and legs, at legs, basically everything, and it still dosn't come out. my only guess is that the blower could be bad? what do you think? how would i go about checking this? thanks.
Old Jun 7, 2003 | 07:06 PM
RAB's Avatar
RAB
Default Re: HELP AC is not working?!!!! (sang)
Take the damn thing out.
Old Jun 7, 2003 | 07:30 PM
Hondaaccordvtec's Avatar
Default Re: HELP AC is not working?!!!! (RAB)
IF your compressor doesn't come on, don't think right away that the compressor is shot. If there is no charge in the system, the computer won't let the compressor come on so that is doesn't burn itself out. You probably have a leak somewhere. Go get it charged with the green dye and find where the leak is.
Old Jun 7, 2003 | 07:50 PM
hagrid's Avatar
Default Re: HELP AC is not working?!!!! (Hondaaccordvtec)
how do you charge it with green dye?
Old Jun 8, 2003 | 12:38 AM
visual's Avatar
**** mine never worked, even when i first got it. I get air that is a lil cooler tham warm but it doesnt condition the air at all.
Old Jun 10, 2003 | 07:43 AM
92LudeSR's Avatar
You could check the connection on the ac pressure switch, take out the plug and measure the resistance on the pins of the switch, if they are shorted out then the freon is ok, check to see if the connections on the plug and the switch need cleaning, I have to clean mine every year or two.
Darrell
E30LS1
Honda Civic (2001 - 2005)
Jul 9, 2014 09:40 AM
JDMDC295
Aug 18, 2007 07:49 PM
c1civic
Apr 11, 2005 11:37 AM
Demon R
May 23, 2004 10:46 PM
Token Blk Guy
Jun 8, 2003 06:00 PM
