H22 ECU Codes
Old Jun 13, 2003 | 01:49 AM
ds2000's Avatar
Default H22 ECU Codes
Hi all,
I've diagnosed my new H22 (just swapped) and have the following three codes:
8 Top Dead Center Position (TDC SENSOR)
12 Exhaust Gas Recirculation (EGR VALVE LIFT SENSOR)
15 Ignition Output Signal
Does anyone have any idea what I need to check for each one to sort it out? The car is running ok but I really want to get rid of this error ASAP
Thanks
Dave
Old Jun 13, 2003 | 02:31 AM
92h22a4's Avatar
If the car is running okay. Reset the ECU and that should clear up the codes. The ECU has a memory and is not real time.
You can remove the battery for a while or remove the ECU fuse located in the fuse box for about 10 - 15 minutes. Put it back and it'll be reset.
Do the test and see if it gives you the codes again.
Old Jun 13, 2003 | 02:36 AM
ds2000's Avatar
Hi,
Sadly the ECU doesn't throw the codes up immediately, it happens after about 5mins of driving, I'll try resetting but I think the problem is far deeper than that.
Thanks
Old Jun 13, 2003 | 03:53 AM
ds2000's Avatar
I think this one:
Is going to be ok, the bypass valve has a snapped end so the vacuum is broken, I'll fix this asap
Tnx
Dave
Old Jun 13, 2003 | 08:07 AM
2point6's Avatar
Default Re: (ds2000)
What year car did you install the H22a in?
Old Jun 14, 2003 | 06:49 AM
ds2000's Avatar
Hi,
The engine was pulled from a 93 and installed into a 95
Thanks
Dave
Old Jun 16, 2003 | 08:34 AM
2point6's Avatar
Swap wires A6 and A11 at the ECU. This should get rid of the EGR code for you.
dookiebox
Engine Management and Tuning
Jan 29, 2013 03:44 PM
Venturello
Apr 13, 2007 01:51 AM
JODYG35950
Dec 15, 2005 06:14 AM
Fatty_1775
Aug 5, 2003 05:37 AM
