intergrated window antenna
Old Jun 7, 2003 | 04:48 PM
cyco's Avatar
Default intergrated window antenna
has anyone done this? as opposed to buying a new antenna, rewiring it so it uses the rear defroster like the 5th gens do? was just wondering if anyone has done this and if it feasable or not.
Old Jun 7, 2003 | 04:57 PM
rjr162's Avatar
Default Re: intergrated window antenna (cyco)
uhh the 5th gen's dont' use the rear defroster. There are two seperate traces on the rear window of the 5th gen... the lower set is the defroster, the upper, and uneven-looking one is the antenna.
Old Jun 7, 2003 | 04:58 PM
cyco's Avatar
Default Re: intergrated window antenna (rjr162)
oh. that makes sense. thanks for clearing that up. but can it still be done?
Old Jun 7, 2003 | 05:23 PM
TRN's Avatar
TRN
seems to me you would have to get the window glass with it inside, which might cost a bit of money just to change something as small as an antenna...
Old Jun 7, 2003 | 05:53 PM
cyco's Avatar
Default Re: intergrated window antenna (TRNRacer)
what i am asking is, is it possible to use the defroster as the antenna by wiring the antenna wire to the defroster?
Old Jun 7, 2003 | 08:23 PM
rjr162's Avatar
you could, if you disconnected the defroster lines. Or, i don't know how this would work out for you, you could take 2 peices of tape, lay them side by side with a small gap, and paint the gap in with that silver metalic paint or whatever.. when it dries it conducts electricity.. it's what you can use to fix a broken section out of a rear defroster. Might work....
dbailey
Honda Civic (2001 - 2005)
Aug 6, 2012 04:53 PM
bmxer
Sep 25, 2007 03:27 PM
9hatch6
May 20, 2006 01:20 PM
rl00
Acura TL, RL & ZDX
Nov 29, 2005 05:01 AM
MestizoRacer310
Sep 21, 2003 05:56 PM
