help!!!
Old Jul 6, 2003 | 01:39 PM
donnjuan2point2's Avatar
Default help!!!
ok heres the deal... intake exhaust clutch and flywheel = 14.60 @ 94.9 with a 1995 jdm vtec lude heres the problem.... intake exhaust type-s cams milled head to 12.0:1 compression = 14.82 @ 93.7 why am i going slower with higher compression and better cams? please help thanx :
Old Jul 6, 2003 | 01:56 PM
optikal_blitz's Avatar
Default Re: help!!! (donnjuan2point2)
sounds like a cam timing issue.
Old Jul 6, 2003 | 02:15 PM
Default Re: help!!! (NatakuBlitz)
i have stock cam gears
Old Jul 6, 2003 | 02:33 PM
skunk2lude01's Avatar
Tuning is key at your stage of modding.
Old Jul 6, 2003 | 11:17 PM
Elkins911's Avatar
Default Re: (skunk2lude01)
sounds to me like you need some adjustable cam gears. dyno tune my friend.
Old Jul 7, 2003 | 10:21 AM
Default Re: (Elkins911)
ok true but even if the cams are at the stock setting would the compression bump from 10.6 to 12.0 give a little more power
Old Jul 7, 2003 | 10:34 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: (donnjuan2point2)
no, b/c at high compression, you need to tune the cams to compensate
Old Jul 7, 2003 | 10:36 AM
Nick M's Avatar
one of these threads is enough.....
EKB18C97
17
May 2, 2006 03:30 PM
c1civic
May 14, 2004 01:27 PM
donnjuan2point2
27
Jul 20, 2003 09:42 AM
donnjuan2point2
Jul 17, 2003 09:31 AM
DIRep972
Jan 16, 2002 07:29 AM
