Will this work?
Old Jul 3, 2003 | 07:43 AM
optikal_blitz's Avatar
Default Will this work?
Hey guys sorry about the constant posting about the foglights. I'm just really anxious to get them working and working properly. Sooo i drew up a wiring diagram based upon collaborative information found across a Mitchell's wiring diagram. so just yes or no, will this plan work??:
Copy/Paste (This URL) for a larger image.
Note: This is for a 92 Lude.
Old Jul 3, 2003 | 07:44 AM
Elkins911's Avatar
Default Re: Will this work? (NatakuBlitz)
you have 2 switches in there.
Old Jul 3, 2003 | 07:50 AM
Default Re: Will this work? (Elkins911)
The 'switch' ontop of the Foglight Relay, isn't an external switch, it's part of the relay- the "switch side".
Old Jul 3, 2003 | 07:53 AM
Elkins911's Avatar
looks like it should work. youll be getting all the power from the dash board fuse block. ideally you should be fine.
Old Jul 3, 2003 | 07:57 AM
rjr162's Avatar
it's hard to tell waht the heck is going on with that switch... I'm assuming it's one that lgihts up when it's got power, along with switching whatever you want. If so, it looks as if it should work fine.
Old Jul 3, 2003 | 08:05 AM
Default Re: Will this work? (rjr162)
to be honest, i dont care if the thing lights up or not- i just want my fogs to come on when i press the button, dig?
oh by the way- sorry for the jumbled lettering on the fog switch. its supposed to be:
(RED/YEL) (RED/GRN)
Old Jul 3, 2003 | 10:27 AM
LudeyKrus's Avatar
Old Jul 3, 2003 | 10:30 AM
LudeyKrus's Avatar
that's a rough sketch of what it should all look like; you don't want the switch on any of the wires connected to terminal #85 or #86 b/c they're gonna be pulling a lot of amperage. The pins #87 and #30 are the switching terminals.
Old Jul 3, 2003 | 10:51 AM
Greyout's Avatar
Default Re: (LudeyKrus)
you're going to be using a switched ground then?
Ludikris - read my sig. I also have an H23 exhaust manifold.
Old Jul 3, 2003 | 11:11 AM
LudeyKrus's Avatar
Default Re: (Greyout)
Yeah, I usually keep the switches on the ground-side of things.
GreyOut - I pm'd ya
Marks accord
Jul 14, 2015 06:30 PM
evrythng_fast
Jul 9, 2011 03:46 PM
raffaelli
Mar 7, 2008 06:09 AM
Tippyman
20
Nov 4, 2006 09:31 AM
Maddhatcher
May 28, 2003 12:22 PM
