simple brake question
Old Jun 29, 2003 | 10:33 PM
MidNiteMysT's Avatar
Default simple brake question
i think recently my brakes havent been braking as hard as they should. i find myself pushing down more then i should. i have power slot rotors with axis mm pads. i think im gonna get myself some stainless steel brake lines. would that solve the problem or is it something else? maybe cuz its really hot outside that it wont brake aswell?
Old Jun 30, 2003 | 12:20 AM
Elkins911's Avatar
Default Re: simple brake question (MidNiteMysT)
air in the system maybe? check to make sure your brake fluid is fulled up too. if you havnt had a recent brake job, that might be the problem too.
Old Jun 30, 2003 | 05:27 AM
user 9782082308's Avatar
Default Re: simple brake question (Elkins911)
How much extra play are you getting and how many miles? If you pump the brakes a few times, does the normal pedal height come back?
Old Jun 30, 2003 | 06:03 AM
Sephro's Avatar
Default Re: simple brake question (racerx)
How much pad do you have left?
Old Jun 30, 2003 | 09:30 AM
Default Re: simple brake question (Sephro)
my brake job was kinda recent. we bleeded the brakes and put on new pads and rotors. it was like 3 months ago or so. im gonna try and press the brakes and see if it comes back to normal height. im not sure if im getting extra play, i just have to press harder on the brakes then i would like to and i think this happened kinda recently. im gonna order some stainless steel brake lines and see how that works out. and ill scrutinize how my brakes are working now.
Old Jun 30, 2003 | 06:47 PM
fe519's Avatar
bleed the master cylinder and each brake again.
Old Jun 30, 2003 | 10:24 PM
Default Re: simple brake question (fe519)
im gonna do that when i get my ss brake lines in about a week or so. hopefully when i bleed them when putting on the new lines, it will work good.
mandoski
Aug 24, 2018 10:41 PM
Jizzmaster Zero
17
Mar 3, 2007 10:04 PM
integra714
Sep 17, 2004 10:29 PM
Ninja Mike
May 27, 2004 07:20 PM
d0nkeyxPunch
Oct 26, 2001 09:28 AM
