high compression and nos
Old Jan 31, 2004 | 10:57 PM
SHhh__VTEC's Avatar
Default high compression and nos
Well, i'm about to start my rebuild but i'm still makin a lil decision. I was thinkin of using a 35 or 50 shot nos when I get done. What i'm not sure is, Can I use type s pistons and so so shot nos (since type s is 11:1 and oem is 10:1)?? I have oem pistons that i probably gonna use unless I get the type s pistons. Or would I be better off using oem pistons and a 50 shot??
Old Jan 31, 2004 | 11:03 PM
@ries's Avatar
Default Re: high compression and nos (SHhh__VTEC)
As long as you have the right amount of fuel and timing... you should be golden. Don't forget to use the right spark plugs
Old Feb 1, 2004 | 07:40 AM
thehondaguru's Avatar
Default Re: high compression and nos (emoBB1)
you forgot the whole tuning thing^^^^^
Thats the most important part
Old Jul 11, 2005 | 11:05 PM
cpforyou's Avatar
Default Re: high compression and nos (95 lude)
Back from the Dead:
So what do you guys think?
CP Pistons 87mm 11.5:1 Compression Pistons
Forged Rods
91 Octane Fuel
w/ Ignition Retard and Hondata Tuning, should be able to handle 75 Shot?
Old Jul 12, 2005 | 12:25 AM
eMpAtHy's Avatar
Default Re: high compression and nos (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">Back from the Dead:
Forged Rods
91 Octane Fuel
w/ Ignition Retard and Hondata Tuning, should be able to handle 75 Shot?</TD></TR></TABLE>
yes.
Old Jul 12, 2005 | 06:26 AM
SPEEDQUEST INC.'s Avatar
Default Re: high compression and nos (eMpAtHy)
Im running stock h23 bottom end with Type S pistons and H22 Head (some work done to it) and 100shot direct port, It has been good so far, again Tunning is the key! good luck
Old Jul 12, 2005 | 07:03 AM
cpforyou's Avatar
Default Re: high compression and nos (SkunkEk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkunkEk &raquo;</TD></TR><TR><TD CLASS="quote">Im running stock h23 bottom end with Type S pistons and H22 Head (some work done to it) and 100shot direct port, It has been good so far, again Tunning is the key! good luck </TD></TR></TABLE>
Then again, what octane do you use?
California only has 91 Octane Gasoline.
Old Jul 12, 2005 | 07:06 AM
California only has 91 Octane Gasoline.</TD></TR></TABLE>
True, I forgot about u guys... I use 93 for the most part because thats what we got uphere....
elmo244
May 30, 2005 12:57 PM
lke2drvgsr
Dec 30, 2003 02:26 PM
lke2drvgsr
29
Dec 7, 2003 08:53 AM
Pinhead
Feb 3, 2002 09:26 AM
