Installing an intake on a 96 lude
Old Jan 28, 2004 | 08:17 PM
Ninjames's Avatar
Default Installing an intake on a 96 lude
I installed a apex n1 on my 96 h22a1 lude
now im going to try an aem cold air intake.... are there any tricks too it... any suggestions? or is it pretty easy?
Old Jan 28, 2004 | 08:25 PM
4bidden's Avatar
Default Re: Installing an intake on a 96 lude (Ninjames)
Easy.
I see you're in Scottsdale....IM me on AIM sometime, I'm in Mesa. I'd love to meet up sometime. There are a couple of us that could get together.
Old Jan 28, 2004 | 08:28 PM
Ninjames's Avatar
that would be sweet i have a few friends we all go cruising around on weekends perhaps a run-in
what kinds of cars do you and your buds have
Old Jan 28, 2004 | 08:33 PM
4bidden's Avatar
Well I've got a few lude friends and we get together every now and then.
IM me on AIM - forbiddenimports
Old Jan 28, 2004 | 08:35 PM
PrecisionH23a's Avatar
Default Re: Installing an intake on a 96 lude (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">Easy.
I see you're in Scottsdale....IM me on AIM sometime, I'm in Mesa. I'd love to meet up sometime. There are a couple of us that could get together.</TD></TR></TABLE>
This is not an internet dating board. How many times do we have to remind you?
Basically the AEM is very straight forward, just yank the stock one off then do some cutting in the bay for fitment of the CAI (the big hole to the left of your battery). A good idea is to line the hole with stan-pro, that way the jagged metal cannot rub against your new intake. You will most likely need to take off your front bumper. You might be able to get away with pulling the plastic lining inside of your wheel well and cutting your wheel. There is also one vacuum line near the right side of the intake manifold that goes to the (i think) secondaries unit that will be need to left open. The intake should come with a little breather to put on that.
Other then that, its pretty straight-forward.
Old Jan 28, 2004 | 08:37 PM
NoLipRacen's Avatar
im up for a little meet in scottsdale... if i can ever work the kinks out of my car!
Old Jan 28, 2004 | 08:41 PM
4bidden's Avatar
Default Re: Installing an intake on a 96 lude (LudeTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">This is not an internet dating board. How many times do we have to remind you? </TD></TR></TABLE>
Focker!
We should get a Prelude thing together here soon. A couple 3gen guys meet up at the Pavilions, but I've yet to make it down there. I'd rather do something else though...that place just makes me mad
Old Jan 28, 2004 | 08:48 PM
Ninjames's Avatar
yeah i have another buddy who has a 92 lude... then i got a buddy with a gsr, si, hatchback, then some other dudes with volkswagen and stuff
but it can be a fun time
Old Jan 28, 2004 | 09:01 PM
VTECRaZeR's Avatar
Well I don't know bout the meeting....'cause I'll be quiet a drive for me..
But about the intake...
Like PrecisionH23a said... you can get away with not taking the bumper off by taking the plastic lining off and removing the plastic piece of crap (forgot the name). It can be kind of tricky taking it off, 'cause you might not be able to see the other screws..
And one more thing don't forget to put the vacuum line hose that goes close to the intake manifold or you'll see your rpm idle jumping. Other then that it's pretty straight forward.
Good luck.
Old Jan 28, 2004 | 09:56 PM
Daboi630's Avatar
Default Re: Installing an intake on a 96 lude (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Other then that, its pretty straight-forward.</TD></TR></TABLE>
dont know what stan-pro is but what i did was used a rubber hose, slit it down the middle and wrapped it around the newly cut hole.
5th Gen AEM in 4th Gen:
Old Jan 28, 2004 | 10:02 PM
Default Re: Installing an intake on a 96 lude (Daboi630)
A split rubber vacuum hose will also do the trick. Stan-pro just makes it look cleaner. Basically it is the hard rubber liner you will see on the inside of your door jams. It has small metal strips inside of it that helps give it a contoured shape and add to it's strength.
Here is a picture of it that I used when I had to fabricate my front radiator support:
http://www.stanpro.com/
Old Jan 28, 2004 | 10:21 PM
Daboi630's Avatar
thanks
Old Jan 29, 2004 | 01:46 PM
4thgenlude's Avatar
its very easy. i have absolutely no mechanical knowledge and i did it in about 20 minutes.
Old Jan 29, 2004 | 01:58 PM
eg6_'s Avatar
Default Re: Installing an intake on a 96 lude (4thgenlude)
good luck, seems like alot of work.
Old Jan 29, 2004 | 03:25 PM
MUGEN-CRX's Avatar
Default Re: Installing an intake on a 96 lude (eg6_)
how's the apex a1 muff... do you see any significant change in power?? is the sound crips... i'm also lookin at that particular exhaust.. but would love to hear more feedback on it.l. thanx how much did you get it for? and one more thing.. you had custom piping along with it right??? how big is your pipes
Old Jan 29, 2004 | 03:44 PM
Ninjames's Avatar
Well thanks alot for all the help guys
maybe i will get a few pictures on here when im done with it.
The intake should come in the mail in about 2 weeks so i will be checking back up with you then
thanks
later
Old Feb 5, 2004 | 05:57 PM
Ninjames's Avatar
welp I installed my intake today and is working awsome... i can sorta tell a difference..there were no check engine lights or anything and i didnt even have to take off my bumper!
thanks to you guys my car is that much cooler
later
jamal-188
May 29, 2007 06:57 PM
TeQz96LudeWyldfyre
Sep 14, 2006 03:42 PM
Jlamar757
Jun 5, 2006 08:39 PM
FWD_4G63T
Oct 22, 2003 12:01 PM
