h22 on f22 tranny?
ive got an f22 preludewith 144k and i was wondering if the h22 motor will be a direct bolton to my f22 tranny, since i think the f22 tranny has longer gear ratios would it be smart to keep it? or should i just get a full h22 swap
thanx for any help
thanx for any help
It will bolt up, just do not expect it to last long. My f22 transmission lasted about 2 months after the swap. I am not sure what went wrong, but a hole a the size of a penny with transmission oil leaking all over the place is definitely not a good thing.
If you want to save money, you can pick up a h23 transmission. It has longer gearing, but the price is cheaper.
there is no reason the f22 tranny would go bad sooner.. its just a different ratio
DrkGreenAccord: i would suspect your f22 tranny wasnt in tip top condition to start out with
I agree, don't half *** the job, down the line you'll regret it. Unless you plan on going the FI route then I would keep it, but if you want to get the most out of your H22A going NA then get the H22A tranny.
o2 jockey
Feb 16, 2004 06:23 AM
