Check engine light, how do you code it?
Old Jan 31, 2004 | 11:18 PM
afterburners's Avatar
Default Check engine light, how do you code it?
my check engine light stays on after I start the motor. It does not flash (blink) how do I jump the p13 ECU to find out which code its throwing? There isn't a LED on my ECU and the Check engine light is constant with the motor running or without!
Old Jan 31, 2004 | 11:32 PM
Default Re: Check engine light, how do you code it? (afterburners)
I found out how to do it with the jumpers, now its flashing 6X fast then 2times slow flash?. will do a search , but why is there a slow two flashes?
Old Feb 1, 2004 | 11:59 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by afterburners &raquo;</TD></TR><TR><TD CLASS="quote">I found out how to do it with the jumpers, now its flashing 6X fast then 2times slow flash?. will do a search , but why is there a slow two flashes?</TD></TR></TABLE>
i believe the slow flashes count as 10,
so it sound's like you have a code 26
Old Feb 2, 2004 | 05:18 AM
98HB's Avatar
Default Re: Check engine light, how do you code it? (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">i believe the slow flashes count as 10,
so it sound's like you have a code 26</TD></TR></TABLE>
That is correct, The quick flashes would be considered as counting as ones and the longer flashes would be counted in multiples of ten. HTH
ITRiWISH
11
Aug 27, 2007 05:24 PM
scoobyjr56
Sep 26, 2006 06:47 AM
willywonka
Jan 12, 2005 05:57 PM
CRX2NV
Apr 29, 2003 11:40 AM
type Gendy
Apr 21, 2003 04:48 PM
