Lowering caused alignment problem
Old Jan 28, 2004 | 06:32 AM
Sandor's Avatar
Default Lowering caused alignment problem
Since my 93 Prelude was lowered, the rear toe is out of the adjustment range. It is currently at -.07, and the service limit is .08 +/- .08 Will the difference between 0.0 and -.07 eat my tires?
Thanks for any help!
Old Jan 28, 2004 | 07:03 AM
Greyout's Avatar
Default Re: Lowering caused alignment problem (Sandor)
its currently a total of .07 degrees toe-out, or each wheel is 0.07 degrees out?
either way, that is a tiny amount, from which you will notice so side effects.
Old Jan 28, 2004 | 07:06 AM
Sandor's Avatar
Default Re: Lowering caused alignment problem (Greyout)
One side is -.07 and the other is -.05 Not at 0.0, but pretty close. Should I raise the car to get within range?
Old Jan 28, 2004 | 07:40 AM
RacingLude's Avatar
When you set the tow it will change your camber. A 2" drop with the toe set to factory will give you a -1.5 camber. Great for Autocross/Track, but you need to rotate your tires to get some life out of them. Or you can get a camber kit or adjustable ball joint.
Old Jan 28, 2004 | 07:46 AM
Sandor's Avatar
Default Re: (RacingLude)
I installed a camber kit, but it's the kind that moves the upper control arm mount at the unibody. So my camber is OK, but toe is off. I should have bought the adjustable ball joint style. Is -.07 enough to shred tires?
Old Jan 28, 2004 | 08:47 AM
lildrgn2.0's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sandor &raquo;</TD></TR><TR><TD CLASS="quote">Since my 93 Prelude was lowered, the rear toe is out of the adjustment range. It is currently at -.07, and the service limit is .08 +/- .08 Will the difference between 0.0 and -.07 eat my tires?
I just went and got my tires realigned (which is what you are supposed to do anyway after you lower your car.)
Old Jan 28, 2004 | 08:54 AM
Sandor's Avatar
Default Re: Lowering caused alignment problem (Lildrgn)
Unfortunately the alignment shop said the eccentric bolt style adjuster is out of range, and there are no adjustable rods made. I could buy adjustable ball joints, but I'd probably choose to raise the ride height before spending more money. I'm hoping it's close enough now.
Old Jan 28, 2004 | 09:20 AM
yohan's Avatar
Should be ok for now ... but really, a camber kit isn't that expensive for our cars. Just that it takes a lot of tweaking to get it right the first time ..
I'm down 1.5" so I'm not going to bother ..
Old Jan 28, 2004 | 10:14 AM
OTT's Avatar
OTT
think i might lower mine; how much is it for a camber kit?
Old Jan 28, 2004 | 10:49 AM
VTECRaZeR's Avatar
Default Re: (OTT)
$130 for a camber kit is the lowest I've seen them, anybody know where to get one for a better price...other then the cheap ebay ones..
Old Jan 28, 2004 | 11:26 AM
Sandor's Avatar
Default Re: (VTECRaZeR)
I got the ebay kind that adjusts the upper control arm where it mounts to the unibody. It was a mistake (although cheap at $100) because it caused the arms in the front to rub the fender and didn't allow extra toe inthe rear. I'd buy the SPC adjustable ball joint kind instead.
Old Jan 28, 2004 | 12:08 PM
OTT's Avatar
OTT
Hmm I think ill avoid the ebay type but will be needing a good kit; Ill see what they offer here in the UK mags tomorrow
Old Jan 28, 2004 | 12:31 PM
del_parker's Avatar
ingalls.
i would make sure that toe is set just right, otherwise you will eat tires like you would not believe.
noz
Suspension & Brakes
Feb 18, 2009 07:53 PM
EF_9
Apr 9, 2008 02:45 AM
98GSRDC2
Suspension & Brakes
Aug 17, 2007 11:10 AM
BigDawwg6969
May 29, 2005 11:42 AM
TSL
May 26, 2005 06:35 PM
