1/2 vtec...
Old Jan 28, 2004 | 08:32 AM
H1PNOT1C PRELUDE's Avatar
Default 1/2 vtec...
Well i bought a prelude about 2 or 3 weeks ago...somewhere around there and when i got it, VTEC didnt engage. So then i checked the usual stuff....oil pressure, solenoid...all of that stuff. I cleaned the film thing on the solenoid and it started working properly and it engaged in every gear, but here is my new problem. Now it will only engage sometimes. An example would be it would engage in 1st, but not in 2nd or 3rd but would engage in 4th, or it wouldn't engage in 1st but it would in 2nd and 4th but not 3rd. If i turn the car off and turn it back on it will engage through all the gears if i never stop getting on it, but then when i stop at a stoplight or somthing like that it goes back to only engaging sometimes.....any ideas of why it would do this? Only thing i can think of is ECU because doesnt the ECU reset everytime the car is turned off? Thanks for the help in advance
Old Jan 28, 2004 | 08:35 AM
Shakes's Avatar
space cadet
Default Re: 1/2 vtec... (H1PNOT1C PRELUDE)
check all of your wires and connections again. then check them after that.
it sounds like you have a problem with it.
and use the enter button dude. it will make your post easier to read.
Old Jan 28, 2004 | 09:11 AM
Asian Persuasion's Avatar
you're hitting vtec in 4th???? that's going pretty fast there dude
Old Jan 28, 2004 | 09:19 AM
ViZ's Avatar
ViZ
Default Re: (Asian Persuasion)
check your oil, h22's are known for burning oil and vtec uses oil pressure so if your low on oil your vtec might not engage
Old Jan 28, 2004 | 10:21 AM
britishlude's Avatar
Check & clean your Vtec solenoid again, check all connections to it make sure all are good, if it still persists think about replacing solenoid. By the way is tranny auto ? if so is the fluid level at max.
Old Jan 28, 2004 | 05:51 PM
jdm22vtec's Avatar
Default Re: (britishlude)
a friend of mine had the same problem. Turned out to be the wiring.
Old Jan 28, 2004 | 08:14 PM
Default Re: (jdm22vtec)
Last time i checked the oil, it was ok, but i will check it again tomorrow. but
no, the car is a 5 spd and i will be checking the wiring after school tomorrow along
with the oil and if problem is still around i guess i will just take it to a honda
dealership so they can rip me off with their high *** labor costs and get it fixed.
Old Jan 29, 2004 | 09:52 AM
LudeyKrus's Avatar
Check the wiring; the oil would have to get really low for it to not kick in VTEC.
Old Jan 29, 2004 | 10:19 AM
Prelude Styl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by britishlude &raquo;</TD></TR><TR><TD CLASS="quote">By the way is tranny auto ? if so is the fluid level at max.</TD></TR></TABLE>
just fyi, 4th gen Vtecs never came with auto trans' in the US.
Old Jan 29, 2004 | 12:01 PM
H22A EG6's Avatar
Default Re: (Prelude Styl)
i belive the only way to reset your ecu is to disconnect the batt.
Old Jan 29, 2004 | 05:40 PM
Thanx for info : wasn't aware of the fact.
Old Jan 29, 2004 | 05:43 PM
4bidden's Avatar
I'll guess oil.
Old Jan 30, 2004 | 07:39 AM
Default Re: (4bidden)
well i fixed the problem, it was the screen on the solenoid, it was filthy as anything
so i just replaced it with one from another solenoid. thanks for all the help
Old Jan 30, 2004 | 09:35 AM
DxTrix's Avatar
Default Re: (H1PNOT1C PRELUDE)
What you need to do is flush your motor. Changing a dirty screen will only solve the problem till it gets full of s@#$.
Old Jan 30, 2004 | 03:35 PM
Default Re: (DxTrix)
Agreed on that flushing oil will help remove the deposits which have probably been breaking loose and causing the solenoid screen to get blocked up, prevention is better than cure, I would give a good flush before you do a normal oil change it's suprising how much sh** comes out when you flush first.
Old Jan 30, 2004 | 03:36 PM
DxTrix's Avatar
Lightsped
26
Jan 8, 2009 02:09 PM
pokmijn
Dec 27, 2007 07:27 AM
92eg6
Feb 9, 2007 09:12 AM
93civicjaydm
Jul 14, 2005 02:59 PM
Dd95Gsr
Jul 24, 2002 02:00 AM
