Saenz Performance 4.364 Final Drive
Old Feb 1, 2004 | 08:46 PM
All-Motor H22A's Avatar
Default Saenz Performance 4.364 Final Drive
Anyone knows if this drops right in, and you'd still be able to use the OEM Honda 1st - 5th Gears?
or must it be used in conjunction with their H-Series Gear Replacement Set
Old Feb 2, 2004 | 02:05 AM
cpforyou's Avatar
Default Re: Saenz Performance 4.364 Final Drive (All-Motor H22A)
4.364 doesn't seem like much of a boost. I'd opt for the 4.4 FD if one is ever made for drag applications.
Old Feb 2, 2004 | 06:23 AM
TimeRacer's Avatar
Why would anyone even consider using this? The difference is so minimal for all the gears that it would be a waste to do the labor. You save < 5 mph per gear (if that much in most). This seems to be a waste of time to even bother doing. There's much better things you can do than changing the final gear less than .1
Old Feb 2, 2004 | 08:11 AM
Daemione's Avatar
Default Re: Saenz Performance 4.364 Final Drive (TimeRacer)
It says the FD is an optional feature - so I assume it could be swapped in independently of the rest of the gear ratios.
As for whether it'd be worth it, it's most likely designed to work best with their more aggressive gearset.
Old Feb 2, 2004 | 08:19 AM
Daemione's Avatar
Default Re: Saenz Performance 4.364 Final Drive (Daemione)
Something I just noticed on the site - http://www.saenzperformance.com/new_prod/index.asp
They say that the guy ran the quarter @ 174.55 mph . . . with a 5th gear of 1.00 (or 1.05), and possibly a tighter FD as well, that's gonna take some mad rpms to get that fast. Either that or really big slicks.
Anyone know what ratios the rest of the gearset is at? And pricing?
Old Feb 2, 2004 | 12:02 PM
fastlude69's Avatar
all someone has to do is call and they should tell you according to the page. also for someone who has more time and finds out the ratios do a comparsion of the gear ratios from that set to stock h22 and h23 trannies
Old Feb 2, 2004 | 03:46 PM
satan_srv's Avatar
Default Re: Saenz Performance 4.364 Final Drive (fastlude69)
"3.091 for 1st, 2.0 for 2nd, 1.412 for third, 1.05 for fourth and 1.00 for fifth."
Might want to keep your 5th gear then..
And by the way, the Euro-R/ATR is 3.285, 2.091, 1.481, 1.071 for reference. so call me crazy but I don't see a huge advantage here, other than availability.
Old Feb 2, 2004 | 05:49 PM
117's Avatar
117
From what I understand after talking with Jamie at Houseman, you cannot mix straight cut and helical cut gears (other than reverse) on the transmission. This is why he doesn't do a straight cut final drive for a stock H22 tranny.
Old Feb 2, 2004 | 05:56 PM
satan_srv's Avatar
Default Re: Saenz Performance 4.364 Final Drive (satan_srv)
geez I just realized those are all straight cut gears...talk about noisy!
Old Feb 3, 2004 | 06:20 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">"3.091 for 1st, 2.0 for 2nd, 1.412 for third, 1.05 for fourth and 1.00 for fifth."
And by the way, the Euro-R/ATR is 3.285, 2.091, 1.481, 1.071 for reference. so call me crazy but I don't see a huge advantage here, other than availability.</TD></TR></TABLE>
Those are the ratios listed for the "dog ring" synchronized box - I'm not sure they're the same for the road race version. I hope not - with the exception of the (useless) 5th gear, there's almost no improvement in the ratios. I'll e-mail them & try to get some more details.
But I totally agree, straight-cut gears will absolutely suck on the street.
Midori Green
Apr 30, 2008 09:11 PM
Renegade
Aug 13, 2003 08:10 AM
slofu
Sep 4, 2002 02:05 PM
Dorikamu
Jun 20, 2002 11:39 AM
