Throttle position sensor
Old Jan 28, 2004 | 02:18 PM
093SiLude's Avatar
Default Throttle position sensor
I have a spare throttle body with the TP sensor broken clean off. I don't see any bolts that hold it to the throttle body. It looks like little rings that are holding it on. How can I replace that, if I can. Thanks
Old Jan 28, 2004 | 02:35 PM
@ries's Avatar
Default Re: Throttle position sensor (093SiLude)
You can either slot them with a die-grinder or hack saw blade. Then use a flat head screw driver and un-screw them. Or just grind them completely off since the tps is already busted.
Old Jan 28, 2004 | 07:42 PM
Hawkze_2.3's Avatar
Yeah, just break it off if it's already broken...then go to a junkyard and find some old accords or something with engines and buy a couple throttle bodies for 30$ and carefully cut and unscrew the screws on the TPS and you got extras...
Or buy one from Honda for $500.....your call
Old Jan 31, 2004 | 02:08 PM
Blanket Jackson's Avatar
K, from Honda they are only 492.50 Get it right!! LOL But yeah, I have a b16a that needs a TPS. Will any old Civic or Accord one work on the motor?? I work at a Honda dealership and the parts guy said the only way he can get a TPS is from a wrecked b16 in a junkyard far far away or brand new with throttle body.
Old Jan 31, 2004 | 02:12 PM
Cottonwoodz's Avatar
Default Re: (HONDAofPOKY)
$394.00 But you do get a shiny new TB with it......
Old Jan 31, 2004 | 03:10 PM
what motor is that for? I got a quote on a b16a for 492 and a quote for an ITR and it was $592.....but thats ghey. I just need the TPS nothing else. Anyone know where I can get one??
Old Jan 31, 2004 | 03:25 PM
Junkyard, is your best bet unless you want to buy a TB from Honda.. $394.00 H22/H23
Old Feb 2, 2004 | 09:08 AM
I understand the junkyard is a place to get one. But for a b16 what TPS will fit it other than the stock one?
Old Feb 2, 2004 | 09:10 AM
Someone said to get the TB's off an older accord and the TPS will come off. Will that TPS work on a b16?
Old Feb 2, 2004 | 01:56 PM
Hawkze_2.3's Avatar
There are only a few designs for the TPS sensors...One points down and the other points up...that's all I've ever seen..
Just check aroung the junkyard for the newest model Honda you can find with an engine and buy the throttle body(it ain't much)...Just make sure it looks exactly like your and it's not broken or covered in mud or anything...
Yes, the Tps will come off and old accord, or any model for that matter, you just have to cut grooves in the bolts to get it off...
Old Feb 2, 2004 | 04:28 PM
yellow_jacket's Avatar
Default Re: (Hawkze_56)
Will one off a 95 Integra work? I've got a whole manifold I was selling for $25. Has all sensors.
eldorko86
Jul 17, 2005 07:19 PM
dmingis
May 28, 2005 09:25 PM
Redsim
Jun 11, 2003 09:37 PM
Inaniac
Oct 21, 2002 12:34 AM
SIcivic10
Sep 29, 2002 05:33 PM
