Methods for removing balljoints
Old Aug 6, 2004 | 07:05 AM
SKDRCR's Avatar
Default Methods for removing balljoints
how many of you guys have removed your balljoints
w/o using the special ball joint tool? what methods did you use.
another question, i'm swapping engines, can I move the car w/o the
axles and engine in the car if I put the ball joints back in?
Old Aug 6, 2004 | 07:09 AM
mstsh80's Avatar
Default Re: Methods for removing balljoints (SKDRCR)
yes you can push the car, just put the susp back together
Old Aug 6, 2004 | 07:18 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">how many of you guys have removed your balljoints
w/o using the special ball joint tool? what methods did you use.</TD></TR></TABLE>
Removed balljoints or separated balljoints?
To separate them, a Pittman arm puller. &lt;$10 at any auto parts store. To remove them, you need a press.
Old Aug 6, 2004 | 07:43 AM
SKDRCR's Avatar
Default Re: Methods for removing balljoints (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">
To separate them, a Pittman arm puller. &lt;$10 at any auto parts store. To remove them, you need a press.</TD></TR></TABLE>
yeah I actually meant seperate them,
so you used a pitman arm puller, hmmmm
Old Aug 6, 2004 | 08:21 AM
prelittlelude's Avatar
well everytime i have to remove or change my axles i just unbolt part of the suspension, and then sway bar and then just pivot the suspension out and pull the axle , works good on tegs too,
but if your really trying to get the ball joint out, your goint to either hav eto make a homeade tool, or go rent one.
what exactly are you trying to do, are the bal joints bad?
Old Aug 6, 2004 | 08:46 AM
SKDRCR's Avatar
Default Re: Methods for removing balljoints (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
what exactly are you trying to do, are the bal joints bad?</TD></TR></TABLE>
swap engines, the balljoints are probably fine
i just need to pull the axles etc.
Old Aug 6, 2004 | 08:48 AM
i just need to pull the axles etc.</TD></TR></TABLE>
oh ok
well in that case, just undo the lower bolt that ties the suspension in,
then undo the sway bar on both sides, and then you can pivot the suspension with everything still attached, and pull the axle out, this is how i have always done it, and it works great, worked on 4 or 5 tegs, and when i swapped my motor and changed my clutch.
Old Aug 6, 2004 | 08:50 AM
SKDRCR's Avatar
oh ok
then undo the sway bar on both sides, and then you can pivot the suspension with everything still attached, and pull the axle out, this is how i have always done it, and it works great, worked on 4 or 5 tegs, and when i swapped my motor and changed my clutch.</TD></TR></TABLE>
koo, thanks for teh help Tom
Old Aug 6, 2004 | 09:18 AM
also you leave the steering attached and everything, just turn the steering wheel accordingly to what ever side you working on, just look at everything on the suspension, you will see how it, works.
the passanger side is kinda tight getting it out, but you will get it
Old Aug 6, 2004 | 10:36 AM
bad-monkey's Avatar
i undo the castle nut halfway and take a hammer to the ball joint and "tap" (or bang the **** out of) the arm on the reinforced part of the arm, and the ball jt pops off.
i've killed a few ball jt grease jackets with arm pullers...
Old Aug 6, 2004 | 10:44 AM
PrecisionH23a's Avatar
Default Re: (bad-monkey)
hitting the ball joint can actually cause damage. Replacing that is more expensive than boot.
Just curious, have any of you guys had the ball joint spin when trying to replace the castle nut back? How did you fix it? I remember it happened to me before on my prelude but I forgot how I fixed it.
Old Aug 6, 2004 | 10:56 AM
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">hitting the ball joint can actually cause damage. Replacing that is more expensive than boot.
Just curious, have any of you guys had the ball joint spin when trying to replace the castle nut back? How did you fix it? I remember it happened to me before on my prelude but I forgot how I fixed it.</TD></TR></TABLE>
ya when the joint started to spin, i think i just put alittle presure on the tappered part just to get it to start to catch, and then you continue to tighten the castle nut, thats always worked for me.
Old Aug 6, 2004 | 11:05 AM
LudeyKrus's Avatar
I've had that happen on two different ball joints before.
The first time, I put a jack up and pushed up on the suspension and it made it catch.
The second time, I just tapped it on w/ my impact wrench. Worked very nicely
Old Aug 6, 2004 | 01:50 PM
SKDRCR's Avatar
oh ok
well in that case, just undo the lower bolt that ties the suspension in ,
so are you talking about number 23 that holds the dampner fork on?
Old Aug 6, 2004 | 01:53 PM
LudeyKrus's Avatar
I think he meant number 6/27.
Old Aug 6, 2004 | 02:04 PM
2point2's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
The first time, I put a jack up and pushed up on the suspension and it made it catch. </TD></TR></TABLE>
i use my small jack right between the ball joint and the wish bone! I clean the ball joint shank and the hole with a bit of brake cleaner to make sure there is no grease.
brings back noobie nightmares..
Old Aug 6, 2004 | 03:08 PM
# 22 26 and 27,
i hadd forgoten about the stablizer so that is number 26
Old Aug 15, 2004 | 11:17 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote"># 22 26 and 27,
i hadd forgoten about the stablizer so that is number 26</TD></TR></TABLE>
well your technique worked Tom. i removed the two lower control arm
bolts, number 22 and 23 and the stabilizer link nut, number 27 and i
was able to push the suspension outward and seperate the axle from the
tranny w/o messing with the balljoints
Old Aug 20, 2004 | 09:20 PM
yohan's Avatar
Just wanted to stop and comment about this thread and talk about how its a BULLSHIT method ... I spent so much time dicking around with hard to reach bolts etc ....
My advice, is this :
Get the pittman arm tool on the lower ball joint just like the helms says ... it wont fit around the lower knuckle and the honda tool has been known to tear the boot ... the pittman will go ABOVE that whol earea, slide the ball joint boot up a little bit so that the tool rests on the metal
take the castle nut and screw it onto the bottom of the ball joint bolt and start to tighten the pittman tool on it ... the castle nut will hold the pitman firm in place and voila ...
within seconds your ball joint pops off (excluding time to remove the cotter pin) ..
It took me an hour to remove both axles after the forks were undone using this method ..
One bolt, one ball joint ... done!
here's a tip on the axles, have a friend pull on the wheel hub while you pry at the shaft etc. and it'll come out SOO much easier ... it was like butter, it slid right out ..
then take the handle off your jack and pound it into the center of the wheel hub to get the other axle out while a friend pulls it .. voila.
Old Aug 20, 2004 | 11:05 PM
Yield's Avatar
pulling slightly on the arm and giving it a light tap of the hammer separated mine just fine on my 10 year old car.
Old Aug 21, 2004 | 12:31 AM
SKDRCR's Avatar
Default Re: (yohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yohan &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to stop and comment about this thread and talk about how its a BULLSHIT method ... I spent so much time dicking around with hard to reach bolts etc .... </TD></TR></TABLE>
how is it a bullshit method? It worked, and took less time and effort than
messing with the spindle nuts and ball joints taht you are referring to.
There are really no "hard to reach suspension bolts" when it comes to this.
Old Aug 21, 2004 | 10:14 PM
yohan's Avatar
I guess if you dont have a 36mm socket or a pittman / ball joint tool it would be a pain and your method migh tbe ok ..
but i also had a huge breaker bar and a friend to help out .. ... I got the spindle nuts off no problem ...
the bolts were on so tight .. if i had an impact tool, it'd be easy no problem but .. with manual labor and sockets it was a bitch for me and my friend .. ...
However, the spindle nuts dont need to be removed to pop the lower ball joint
Old Aug 22, 2004 | 12:26 AM
H22A EG6's Avatar
Default Re: (yohan)
i just got one of those forks and pounded the **** outa it it was really easy but not nice to the boots
Old Aug 22, 2004 | 01:02 AM
ph8ed4life's Avatar
Default Re: (H22A EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">i undo the castle nut halfway and take a hammer to the ball joint and "tap" (or bang the **** out of) the arm on the reinforced part of the arm, and the ball jt pops off.
i've killed a few ball jt grease jackets with arm pullers...</TD></TR></TABLE>
this is the way I've done 5 axle related repairs(engien swaps, axle replacements, etc) in hondas alone, and the way I've taken various ohter gm/ford suspensions apart...just gotta know where to hit it and not get irritated at the fact that it might take more than 3 swings
Old Aug 22, 2004 | 01:04 AM
ph8ed4life's Avatar
Default Re: (ph8ed4life)
The second time, I just tapped it on w/ my impact wrench. Worked very nicely </TD></TR></TABLE>
Crx_Civic
11
Oct 20, 2007 04:10 AM
skata89
Mar 30, 2006 06:41 PM
ricebowl
Oct 11, 2005 11:39 PM
JDMlyfestyle
41
Dec 5, 2004 07:18 PM
xerox445
Feb 9, 2004 09:54 AM
