ground points?
Old Aug 9, 2004 | 04:10 PM
puffxy's Avatar
Default ground points?
because of a wierd idle problem and some staticy electrical noise everyone believes to be a bad ground, i decided to hunt down grand points around the car. I've only spotted a few;
1) the most obvious negative (-) battery terminal.
2) engine head/block
and i tried following the alternator ground but it runs behind the head and i can't get to it.
anyways, how many grounds are there and where are they?
i'm just hoping their not impossible to access.
thanks.
Old Aug 9, 2004 | 04:18 PM
Behan's Avatar
Default Re: ground points? (puffxy)
there is a ground from the neg batt cable to the trans. You should also have a ground wire coming off the neg. cable directly to the radiator support.
Also the drivers side of the valve cover has ground which attaches near the motor mount.
Three that i can think of, off the top of my head.
Old Aug 9, 2004 | 07:05 PM
puffxy's Avatar
^ got those, thanks!
any others?
acmoc
Jan 19, 2011 07:49 AM
nonpareil
Mar 12, 2010 04:58 AM
96b18c
Jun 3, 2004 07:29 PM
ophdehEEzY
Apr 1, 2003 01:30 PM
S13Koop
Aug 12, 2001 04:21 PM
