V-tec problem in 1st gear
Old Aug 9, 2004 | 03:25 PM
Phillip4288's Avatar
Default V-tec problem in 1st gear
I have a 2000 honda prelude sh. In first gear at about 5500 rpm's it starts to stutter.. i run premium gas in it.. .. when it starts to stutter.. it will go into vtec and feel like it goes back out? any help here ?PLEASE!!!
Old Aug 9, 2004 | 03:32 PM
charliec's Avatar
Default Re: V-tec problem in 1st gear (Phillip4288)
have you checked your oil? any CELs?
Old Aug 9, 2004 | 03:47 PM
ludermark's Avatar
Default Re: V-tec problem in 1st gear (charliec)
your oil level is very low...i guarantee it...PUT OIL IN YOUR CAR !
Old Aug 9, 2004 | 05:16 PM
Default Re: V-tec problem in 1st gear (ludermark)
wow.. check oil
hardly none?
THANK YOU SO MUCH
WHAT OIL SHOULD I USE? SYNTHETIC OIL?
Old Aug 9, 2004 | 05:22 PM
Behan's Avatar
You probably had regular oil in there before, so use that. If you want to switch to synthetic use a synthetic blend ( half reg/half syn) on your next oil change. Then use full synthetic the next time you change it.
Old Aug 9, 2004 | 05:28 PM
Default Re: V-tec problem in 1st gear (Behan)
Ok. I went and craked the lude. Let it run for about 2-3 min. Turned the motor off. Checked the oil.. I had plenty. Stuck the stick back in. Waited 5 seconds.. Pulled it out.. I had none? Whats that mean?
Old Aug 9, 2004 | 05:31 PM
ludermark's Avatar
trust me your oil is low...fill it up. i reccomend taking a different car to go to get because if you run your car with oil that is so low you will do damage to your internals.
Old Aug 9, 2004 | 05:35 PM
yea, Im going to go get it changed tomorrow. I just found it odd that I had PLENTY on the stick as soon as i turned the car off. Then 5 sec later.. I had none? Kinda odd. Thanks so much for your help though man. i really appreciate it
Old Aug 9, 2004 | 05:46 PM
ludermark's Avatar
no problem.
Old Aug 9, 2004 | 09:26 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phillip4288 &raquo;</TD></TR><TR><TD CLASS="quote">yea, Im going to go get it changed tomorrow. I just found it odd that I had PLENTY on the stick as soon as i turned the car off. Then 5 sec later.. I had none? Kinda odd. Thanks so much for your help though man. i really appreciate it </TD></TR></TABLE>
no oil leaks?
Old Aug 9, 2004 | 11:05 PM
FadedEpic's Avatar
Default Re: V-tec problem in 1st gear (SKDRCR)
Wow its posts like this that make me wanna learn sooo much. he told you like two things about his car and all you guys knew the problem.
IntegraType-R
Oct 15, 2006 09:14 PM
RemerLex11
Aug 4, 2004 09:36 AM
SpoonFedHatch
Jul 10, 2004 08:51 PM
SoNNyBoY9o9
Mar 11, 2003 07:15 AM
Type R 01
Feb 12, 2003 04:35 AM
