A/C Compressor problem!
Old Aug 8, 2004 | 05:15 PM
92whiteSi's Avatar
Default A/C Compressor problem!
One thing i have found to be different on the h23 and the h22 are that the crank pulley on the h22 has one more rib on it for the compressor for the A/C the other belt has the same # of ribs but what should i try to do about this? SHould i try to pull the pulley off the old compressor and put it on the new one. I REALLY REALLY dont want to diconnect the A/C lines and have to refill them or anythign so im not sure what to do. Anyone else have this problem?
Old Aug 8, 2004 | 05:21 PM
Behan's Avatar
Default Re: A/C Compressor problem! (92whiteSi)
swapping ac pulleys would be the easiest solution. You may be able to do it with the compressor in the car, but i doubt it.
It would be easiest with air tools.
Old Aug 8, 2004 | 05:42 PM
92whiteSi's Avatar
we have air tools, and u think it is possible without disconnecting the a/c lines?
Old Aug 8, 2004 | 06:07 PM
Behan's Avatar
Default Re: (92whiteSi)
If you can get the wrench on the pulley without removing it, then i don't see why you would have to remove the lines.
However i doubt the impact will fit, maybe a ratchet style air tool???
Old Aug 8, 2004 | 06:10 PM
92whiteSi's Avatar
everything is out of the car and on the floor besides the old A/c Compressor which is losely hangin in the empty engine bay. so space isnt an issue.
Old Aug 10, 2004 | 12:42 PM
92whiteSi's Avatar
bump
Crobran
Jan 28, 2017 06:15 AM
Drazz
May 1, 2013 06:57 AM
Flamenco-T
Aug 1, 2003 09:45 PM
