MSD EXT. COIL
Old Aug 7, 2004 | 01:10 PM
vteckilla7's Avatar
Default MSD EXT. COIL
OK, I think my ignition coil may be bad, or might just be the wire???, thinking about just getting a blaster coil, how would i wire this up???, and what would i do with the plug that normally goes to my factory coil, any1 help???
Old Aug 18, 2004 | 05:15 AM
Xsi's Avatar
Xsi
If you have a stock internal coil you need to extend the wires out to the external coil and run a coil wire to the dizzy cap.
Old Aug 18, 2004 | 06:29 AM
Revi's Avatar
Default Re: MSD EXT. COIL (vteckilla7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckilla7 &raquo;</TD></TR><TR><TD CLASS="quote"> OK, I think my ignition coil may be bad, or might just be the wire???, thinking about just getting a blaster coil, how would i wire this up???, and what would i do with the plug that normally goes to my factory coil, any1 help???</TD></TR></TABLE>
If you have an external coil like the 97-01 ludes, all you need to do is wire all the +wires to the +terminal on the coil, and the rest of the wires to the - terminal. Get a current meter and test the wires, any that show current will be connected to the +terminal.
Horseofcourse
Apr 11, 2008 10:33 AM
AznBlueBoy
Jul 8, 2004 02:25 PM
Que_Lude
Sep 11, 2002 08:38 PM
Steve Berman
Aug 22, 2002 04:52 PM
darklude111
Mar 3, 2002 06:53 PM
