h23 head problems
Old Sep 30, 2004 | 03:36 PM
Xbstd23X's Avatar
Default h23 head problems
i adjusted my vavle lash and when i started my car up it was fine then a tickin started. not sure what it was but its louder than before i did my vavle lash.
anyone got any clues on what it could be and how hard it would be to fix
Old Sep 30, 2004 | 04:08 PM
LudeyKrus's Avatar
Well H23's are normally kinda loud, but doublecheck all your lash settings, then maybe do a compression test, if ya got a gauge handy.
Old Sep 30, 2004 | 06:03 PM
Xbstd23X's Avatar
Default Re: (LudeyKrus)
its really loud
but ill try to check it out
Old Sep 30, 2004 | 06:16 PM
SUB-0 H23's Avatar
Default Re: (Xbstd23X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xbstd23X &raquo;</TD></TR><TR><TD CLASS="quote">its really loud
but ill try to check it out</TD></TR></TABLE>
yeah, you probably did not adjust one of them correctly, it happen to me once
Old Sep 30, 2004 | 07:39 PM
Hawkze_2.3's Avatar
Default Re: (SUB-0 H23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUB-0 H23 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, you probably did not adjust one of them correctly, it happen to me once </TD></TR></TABLE>
Couldn't agree more...it's very hard to know what a "slight amount of of drag" is exactly on your first time. Try it again and you'll get the feel for it a little better.
Old Sep 30, 2004 | 07:45 PM
Xbstd23X's Avatar
Default Re: (Hawkze_2.3)
o this is my 3rd time i should of mentioned that earlier but it doesnt start right away like before it takes about half a minute to start ticking
Old Sep 30, 2004 | 07:51 PM
Hawkze_2.3's Avatar
Does it ever go away?
Old Sep 30, 2004 | 07:53 PM
Xbstd23X's Avatar
nope it doesnt go away
another problem i ran into is
mid rpms like 3k-5k its really jumpy (like when your learnin how to drive stick)
some people told me its pry that my tables are off on my hondata
Old Sep 30, 2004 | 07:56 PM
Hawkze_2.3's Avatar
What did you adjust them too? Sounds like the 2nd problem could be the Hondata...
Old Sep 30, 2004 | 07:57 PM
Xbstd23X's Avatar
intake was .005 and exhaust was .007
is there anyway to fix that without retuning it
and what happend to my old tables
Old Sep 30, 2004 | 07:58 PM
Hawkze_2.3's Avatar
I don't know a lot about Hondata, but try .003(in.) and .006(ex) on your valves...that always works for me...
Old Sep 30, 2004 | 08:00 PM
Xbstd23X's Avatar
alright ill try that out
do you have stock cams or anything done to your head
Old Sep 30, 2004 | 08:02 PM
Hawkze_2.3's Avatar
S-s-s-s-stock cams, rebuilt stock head
Old Sep 30, 2004 | 08:06 PM
Xbstd23X's Avatar
damn same here
well ill pry check into that tomorrow and ill post back on what i find out
if its not that do you have any clues on what else it could be
Old Oct 3, 2004 | 07:29 PM
Xbstd23X's Avatar
could it possibly be a bent vavle
i didnt adjust my vavle lash again but someone told me that it could be a bent vavle
Old Oct 3, 2004 | 09:30 PM
Freemantle's Avatar
The delay in onset of the ticking noise probably has to do with the temperature of the oil in your bearing journals. Your clearances drop a little lower when the oil is at warm viscosity, which is enough to give you seating problems.
tn265
Jul 21, 2006 05:46 PM
fastludeh22
Feb 4, 2005 07:40 PM
mrxhe1neken
Jan 15, 2005 09:38 AM
Spunkster
Dec 11, 2004 07:57 AM
shyboy_02
Sep 28, 2003 09:12 PM
