Nitrous users
Old Oct 4, 2004 | 06:00 PM
dvae's Avatar
Default Nitrous users
Just curious as to what size shots your running, and at what point if when do you have to upgrade injectors/pump. Mildly modded (I/H/E, and cams soon) and nx wet kit planning on 75 shot. Should I be all good, or do I have to upgrade stuff. I tried search and found no answers, and since I'm a ford guy all this honda stuff is new to me.
Old Oct 4, 2004 | 06:32 PM
jdm_loser's Avatar
Default Re: Nitrous users (dvae)
[QUOTE=dvae]Just curious as to what size shots your running, and at what point if when do you have to upgrade injectors/pump. Mildly modded (I/H/E, and cams soon) and nx wet kit planning on 75 shot. Should I be all good, or do I have to upgrade stuff. I tried search and found no answers, and since I'm a ford guy all this honda stuff is new to me.[/QUOTE
upgrade fpr, fuel pump, retard timing couple of degrees, colder spark plugs, do compression test, cant really think of anything else
Old Oct 4, 2004 | 06:43 PM
H22NOSACC's Avatar
I was fine with the stock FPR and a holley 255 pump it had me a 44psi. I also ran a race plug so i could go down 2 steps colder. The 75 shot worked great up until last thursday when the motor blew on the dyno. I don't think the shot was to blame more of the fact the guy engaged the nitrous at to low of an rpm.
dvae's Avatar
Default Re: Nitrous users (throwed)
Thanks for info. As this motor isn't going to be sprayed all the time, can I keep timing stock so I don't lose power then maybe just run a little less shot, or does a couple degrees timing not even hinder you that much.
Old Oct 4, 2004 | 06:44 PM
dvae's Avatar
Default Re: Nitrous users (H22NOSACC)
Why would nitrous being engaged at low rpm blow motor?
Old Oct 4, 2004 | 06:47 PM
01 LudeDude's Avatar
I run a dry 50 shot, but it's more for cooling off the JRSC than anything
Old Oct 4, 2004 | 09:08 PM
DVS Luder's Avatar
Default Re: Nitrous users (01 LudeDude)
Im not too sure what the rules are, like about asking a different question in a thread, kind of like what Im about to do. Anyways its kind of related so I hope I ain't breaking any rules, but ok my question is: When trying to buy a used car, is there any way you can see if the owner previously used nitrous? (cuz I think most people would rather buy a car that wasn't squeezin' that stuff). I have never seen a car with nitrous in person so I wouldnt know what to look for. Ok thanks
Old Oct 4, 2004 | 11:02 PM
Luchini's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22NOSACC &raquo;</TD></TR><TR><TD CLASS="quote">I was fine with the stock FPR and a holley 255 pump it had me a 44psi. I also ran a race plug so i could go down 2 steps colder. The 75 shot worked great up until last thursday when the motor blew on the dyno. I don't think the shot was to blame more of the fact the guy engaged the nitrous at to low of an rpm.</TD></TR></TABLE>
Man I would be pissed if this dude did that to my car. Were you pissed and like wtf?
Old Oct 5, 2004 | 06:00 AM
eLUDEnu
Guest
Posts: n/a
Default Re: Nitrous users (Luchini)
I dont see how you can spray at to low of an rpm I spray from a dead stop everyday
Old Oct 5, 2004 | 08:56 AM
SKDRCR's Avatar
Default Re: Nitrous users (eLUDEnu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLUDEnu &raquo;</TD></TR><TR><TD CLASS="quote">I dont see how you can spray at to low of an rpm I spray from a dead stop everyday</TD></TR></TABLE>
That's first gear though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvae &raquo;</TD></TR><TR><TD CLASS="quote">Why would nitrous being engaged at low rpm blow motor?</TD></TR></TABLE>
I believe it puts too much stress on the crank (rotating assembly)
and works too hard to build up rpms.
Someone correct me if I'm wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DVS Luder &raquo;</TD></TR><TR><TD CLASS="quote">Im not too sure what the rules are, like about asking a different question in a thread, kind of like what Im about to do. Anyways its kind of related so I hope I ain't breaking any rules, but ok my question is: When trying to buy a used car, is there any way you can see if the owner previously used nitrous? (cuz I think most people would rather buy a car that wasn't squeezin' that stuff). I have never seen a car with nitrous in person so I wouldnt know what to look for. Ok thanks</TD></TR></TABLE>
Hard to say.
See what plugs he has in it.
Check the Ignition timing.
See if there is an extra hole in the intake where
he might have previously had a nozzle/jet.
See if there are any holes in the trunk where
he might have routed the nitrous lines to the bottle.
Old Oct 5, 2004 | 05:50 PM
H22NOSACC's Avatar
It was on a dyno, the guy started the pull at 35mph IN FORTH GEAR. Way to much stress on the motor, plus I don't think the ecu really liked it much either(timing, fuel). The guy was a dyno newbie so that played a factor. I've sprayed from a dig tones of time and have even bogged it in 2nd and had to go through the whole powerband with it on without a problem. The car hauled *** with the 75shot F**k I miss it.
Oh and the NX kit say that there is no timing retard needed so I never retarded mine.
Old Oct 5, 2004 | 05:51 PM
H22NOSACC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luchini &raquo;</TD></TR><TR><TD CLASS="quote">
Man I would be pissed if this dude did that to my car. Were you pissed and like wtf?</TD></TR></TABLE>
Ya I'm stilled pretty pissed...it hasn't even been a week yet
Old Oct 5, 2004 | 05:55 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22NOSACC &raquo;</TD></TR><TR><TD CLASS="quote">It was on a dyno, the guy started the pull at 35mph IN FORTH GEAR. Way to much stress on the motor, plus I don't think the ecu really liked it much either(timing, fuel). The guy was a dyno newbie so that played a factor.
This is why I go somewhere will they'll let you
make the pass on the dyno.
I've sprayed from a dig tones of time and have even bogged it in 2nd and had to go through the whole powerband with it on without a problem. The car hauled *** with the 75shot F**k I miss it.</TD></TR></TABLE>
Just because it never went *Boom* before when you did that doesn't
mean you weren't tearing up your motor.
Oh and the NX kit say that there is no timing retard needed so I never retarded mine.</TD></TR></TABLE>
I still would of retarded it a little with a 75 shot.
Old Oct 5, 2004 | 06:12 PM
Default Re: Nitrous users (SKDRCR)
I would agree, atleast a few degree.
GetawayInMoscow
Sep 17, 2006 05:03 PM
TylerC
Jun 20, 2005 10:14 AM
1INTEGRA
Feb 23, 2004 01:21 PM
94EGproject
Sep 30, 2003 07:40 PM
toEknEEg
Dec 22, 2002 01:01 AM
