Shaking
Old Oct 1, 2004 | 08:29 PM
dcrbin22's Avatar
Default Shaking
my car recently started shaking at speeds above 60. It never did this before i never changed the front tires or anything. I can feel it in the gas pedal and steering wheel , its worse on the highway when turning just on a slight turn. Could the wheels come out of balance i havent hit anything.
Old Oct 2, 2004 | 12:09 AM
BrokeLude's Avatar
Default Re: Shaking (dcrbin22)
More details would be nice, but it sounds like a CV joint. Is it worse with acceleration?
Old Oct 2, 2004 | 12:57 AM
britishlude's Avatar
Wheels can lose their balance if you've lost a balance weight, also check your tires real good for any damage like bulges or flat spots in case it's a tire causing it, also check your lug nuts are torqued up to spec.
Old Oct 2, 2004 | 11:37 AM
dcrbin22's Avatar
Default Re: Shaking (BrokeLude)
No worse under acceleration i can put can put the clutch in on the highway and its the same shaking.
Old Oct 2, 2004 | 02:59 PM
BlissSkr's Avatar
your tires are definetly out of balance if its 60above but it should smooth out around 90, u might also want to take a look at ur springs i had a cracked one that broke and it was a similar problem. But it sounds like the tires (take it from me i deal with them all day everyday at work)
Old Oct 3, 2004 | 09:36 PM
dcrbin22's Avatar
Default Re: Shaking (BlissSkr)
yeah sounds like it to me it does start to go away at 90
Old Oct 3, 2004 | 11:04 PM
BrokeLude's Avatar
I agree. Check the balance and also make sure there are no lumps etc...
Old Oct 5, 2004 | 10:01 AM
prelude97's Avatar
That's extactly what my car does around 60-80 it shakes once im over 80 it smoothes out!! how much is it to get that problem corrected can I go to any tire shop to fix this???
Old Oct 5, 2004 | 10:04 AM
Elkins911's Avatar
Default Re: Shaking (prelude97)
no need to fix it, just go above 80 and below 60. in socal, those are the only speeds we know.
Old Oct 5, 2004 | 10:48 AM
donniebrasco's Avatar
Default Re: Shaking (Elkins911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">no need to fix it, just go above 80 and below 60. in social, those are the only speeds we know. </TD></TR></TABLE>
He's got a point But try an alignment.
Old Oct 5, 2004 | 11:46 AM
Freemantle's Avatar
Default Re: Shaking (donniebrasco)
Alignment won't do dick for shaking. I know, I do them. You either lost a balance weight (which isnt hard) or you have some serious wheel bearing/tie rod-end issues.
Old Oct 5, 2004 | 02:23 PM
prelude97's Avatar
I just checked my wheels the front right has no tire balances where do i go to fix this?
Old Oct 5, 2004 | 03:06 PM
Any reputable tyre centre that deals in alloys and tyres and has computerised wheel balancing equipment, should do you a good job for a few bucks a wheel. Best to at least get the two fronts done or all four if you want peace of mind.
Old Oct 5, 2004 | 04:47 PM
dcrbin22's Avatar
Default Re: Shaking (Freemantle)
Could a blown shock do this ? I just noticed today my passenger side bilstein is done , the car rides like crap. You can feel that side bouncing around.
Old Oct 5, 2004 | 09:28 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">More details would be nice, but it sounds like a CV joint. Is it worse with acceleration?</TD></TR></TABLE>wheel bearing
deerman2701
Jan 17, 2009 08:05 AM
civicsracer
Dec 5, 2006 05:30 PM
EnjoyTheRideDC2
Suspension & Brakes
Aug 31, 2006 07:45 AM
Ed 341
Aug 14, 2006 04:02 PM
hi mom
Jul 8, 2004 09:12 PM
