MAP Sensor
Old Oct 5, 2004 | 10:29 AM
Wiseguy619's Avatar
Default MAP Sensor
Awhile back I posted a thread asking if anybody had any assumptions of why I was getting shitty gas mileage. Just to refresh, I used to get around 300-330, now I am getting around 220. I was given a couple suggestions, but could not pinpoint the problem. A couple weeks ago my CEL turned on. I scanned it at my work, and it gave the code for a MAP sensor. I am pretty sure that would explain my bad gas mileage and loss of power. I checked out the MAP sensor, and it was really loose and had some carbon build up in it. Does anybody know how much these cost?
Old Oct 5, 2004 | 02:34 PM
Mikey3000's Avatar
Default Re: MAP Sensor (ProjectPenny)
they're pretty expensive if u get them from the dealership. over $100. your best bet would be to try to find one from a salvage yard. you dont have to get one off a Prelude, u just have to get one off any other Honda/Acura from the same OBD (i.e. OBD1, 2).
Old Oct 5, 2004 | 03:54 PM
LudeyKrus's Avatar
I may have a spare MAP sensor sitting around, i'll check tonight. If not, grab one from a junk yard.
And yes, that would explain your problems. Mine went bad when I let my car sit for a year while I built my motor.
Old Oct 6, 2004 | 08:06 AM
Wiseguy619's Avatar
Default Re: MAP Sensor (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to get one off a Prelude, u just have to get one off any other Honda/Acura from the same OBD (i.e. OBD1, 2).</TD></TR></TABLE>
I did not know that, thanks. I called Honda and they said the MAP sensor cost $50. Originally I thought it was going to be over $100.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I may have a spare MAP sensor sitting around, i'll check tonight.</TD></TR></TABLE>
If you can check that would be cool, thanks.
Old Oct 7, 2004 | 12:17 AM
Wiseguy619's Avatar
bump
jdmacuraITR
Aug 15, 2014 09:31 PM
zaks1
14
Dec 4, 2012 10:24 AM
justinb
Jun 2, 2005 03:39 PM
94 civic all mtr
Dec 20, 2003 08:18 AM
