Will Skunk2 Intake Manifold throw codes?
Old Sep 30, 2004 | 09:38 AM
frostee's Avatar
Default Will Skunk2 Intake Manifold throw codes?
I know the skunk2 IM doesnt use the second butterfly, but the second butterfly has a sensor attached to it, and I hear that it doesnt use the egr valve system, so wouldnt that trigger codes? Just wondering...... any help would be appreciated, thanx.
Old Sep 30, 2004 | 09:39 AM
98TypeSH's Avatar
Default Re: Will Skunk2 Intake Manifold throw codes? (frostee)
On an OBD-2 car, if you dont leave the EGR plugged in, yes you will throw a code.
I did tons of other crap to my car,so, as a result i have no EGR code to throw with an OBD-1 ECU
Old Sep 30, 2004 | 09:42 AM
frostee's Avatar
I have an obd1 setup, so how would you go about killing the egr and second butterfly sensors? Do you just unplug them?
Old Sep 30, 2004 | 09:47 AM
98TypeSH's Avatar
OBD-1 computers never included EGR capabilities. Just pull the thing off, same when you uninstall the iabs. Secondaires dont throw a code
Soon as you swap manifolds, your finished. EGR gone iabs gone.
Old Sep 30, 2004 | 09:53 AM
frostee's Avatar
Default Re: Will Skunk2 Intake Manifold throw codes? (98TypeSH)
kewl, I hope It's as simple as it sounds.
Old Sep 30, 2004 | 10:03 AM
98TypeSH's Avatar
Actually, it isnt. To tell you the truth, you are going to hate your life installing this manifold. There is also this huge skunk2 intake manny thread, this will probably either be moved there or deleted/locked.
I dropped 2 manifold bolts pulling the stock manifold off, it took me 3 hrs to find 2 bolts, lol. good luck. Label everything you pull off, and make sure you relieve fuel pressure first and recoat the injector seals with fresh motor oil.
Old Sep 30, 2004 | 10:17 AM
frostee's Avatar
hehehe.... i guess i was being a bit lazy not wanting to go through them posts, I hope i dont hate myself for installing it, I should put it on my head b4 dropping the motor in i guess, so i dont lose bolts.
Old Sep 30, 2004 | 10:19 AM
98TypeSH's Avatar
YES, do that. If you got the motor out of the car, you may as well. It may not clear the firewall, so if you have the head off put it on the head then put the head on.
Trail and error my friend.
Old Sep 30, 2004 | 10:28 AM
frostee's Avatar
this is way off the topic, but what's that 100% by my post count for?? J/W cuz im a noob here....
and would it be easier to install it w/ the head off the block or on the block? I would assume on the block.....
Modified by frostee at 11:47 AM 9/30/2004
Mccormick009
Nov 7, 2014 12:46 AM
Mfoehrkolb
Sep 8, 2008 09:10 PM
b20izzle
Feb 4, 2005 01:04 PM
B_CRUZ!
May 20, 2002 02:16 PM
