prelude engine code
Old Nov 30, 2004 | 07:32 PM
CivicVX94's Avatar
Default prelude engine code
alright let me start off by saying i'm prelude illiterate. i really don't know **** about them, I perfer the slower 4 bangers like civics
my friend has an late 80's to early 90's prelude, i don't know what year, and he says it has a sohc 12 valve in it? I searched a lot and I can't find any prelude engine to fit that discription. I've read about the b20a3 and a5's in the 90 and 91 ludes, but those are dohc 16 valves.....he also said it's the stock engine, and one more thing even if it has a swap it's not the 70hp civic cx engine (d15b2 or b-whatever it sucks who cares? ) and that's the only engine i can find that fits this discription.
so can anyone provide me with a prelude engine code list or tell me what engine this can be? Thanks for any help
o and the only reason I care is cause he's selling it and i'm interested, but we were working and didn't have any time to talk about it
Old Nov 30, 2004 | 07:48 PM
CivicVX94's Avatar
Default Re: prelude engine code (CivicVX94)
bump.....no ones even read this yet!!!!!!!!!!!!!c'mon boys help me out here
Old Nov 30, 2004 | 07:49 PM
v4lu3s's Avatar
RTFM
sounds like an a20 or a18 engine.
Old Nov 30, 2004 | 07:57 PM
CivicVX94's Avatar
Default Re: (v4lu3s)
thanks, can you get any specs on that?
Old Nov 30, 2004 | 07:58 PM
v4lu3s's Avatar
RTFM
not offhand, but im sure if you use gogole and look for somethign liek a20a1 or a18a1 etc you can pull some info. i know the best of the A series waas teh a20a3 in teh 87-89 accords with 122hp and fuel injections. if that one has a carb its not got much power though.
Old Nov 30, 2004 | 08:38 PM
CivicVX94's Avatar
cool thanks for the help man, i'll post up my results
Old Nov 30, 2004 | 10:20 PM
car_boy_16's Avatar
Default Re: (CivicVX94)
You're probably thinking of the 3rd generation Prelude S (1988-1990) with the B20A3 which is a SOHC 3 valve per cylinder engine which obviously makes 12-valves total. It's only got like 104hp and it runs off 2 side-draft carburetors. The car is not fast, it should handle pretty well but definately no straight line racer.
Old Nov 30, 2004 | 10:22 PM
car_boy_16's Avatar
Default Re: (car_boy_16)
I didn't see that you're considering buying the car....Personally, I would look for a 2.0Si or Si model, and skip the S models. The brakes, engines, and overall power options are substandard and are much better on the 2.0Si and Si models.
Old Nov 30, 2004 | 10:44 PM
tdo's Avatar
tdo
heres some
it goes like this
Year | Model | country | code | power | torque | cam | OBD | vtec
'79-'91 _ USA EK 1 72hp@4500RPM 94lb ft@3000RPM ? ? ?
'82 _ USA EK 1 75hp@4500RPM 96lb-ft@3000RPM ? ? ?
'83-'84 _ USA ES1 100hp@5500RPM 104lb-ft@4000RPM ? ? ?
'85-'86 _ USA ET2 100hp@5500RPM 104lb-ft@4000RPM ? ? ?
'86 Si USA BT 110hp@5500RPM 114lb-ft@4500RPM ? ? ?
'87 _ USA A18A1 100hp@5500RPM 107lb-ft@4000RPM ? ? ?
'87-'91 2.0 Si USA B20A5 110hp@5500RPM 114lb-ft@4500RPM ? ? ?
'88-'90 S USA B20A3 100hp@5500RPM 107lb-ft@4000RPM ? ? ?
'90-'91 Si USA B21A1 140hp@5800RPM 135lb-ft@3500RPM ? ? ?
'92-'96 S USA F22A1 135hp@5200RPM 142lb-ft@4000RPM DOHC 1 or 2 No
'92-'96 Si USA F22B 160hp@6000RPM 148lb-ft@5000RPM DOHC 1 or 2 No
'92-'96 SE/Si USA H23A1 160hp@5800RPM 156lb-ft@4500RPM DOHC 1 or 2 No
'92-'96 VTEC USA H22A 200hp@6800RPM 161lb-ft@5500RPM DOHC 1 or 2 Yes
'93-'95 Type-S Japan H23 160hp@5800RPM 156lb-ft@4500RPM DOHC 1 No
'94-'96 VTEC USA H22A1 190hp@6800RPM 158lb-ft@5500RPM DOHC 1 or 2 Yes
97-'98 _ USA H22A1 195hp@7000RPM 156lb-ft@5250RPM DOHC 2 Yes
'97-'01 Type-S Japan H22A 200hp@7200RPM 163lb-ft@6500RPM DOHC 2 Yes
'97-'01 SiR Japan H22A 220hp@7200RPM 163lb-ft@6500RPM DOHC 2 Yes
'99-'01 _ USA H22A 200hp@7000RPM 156lb-ft@5250RPM DOHC 2 Yes
Old Nov 30, 2004 | 11:24 PM
street_ruler's Avatar
the b20a3 is the carbed 12 valve...honda used carbs on preludes till 91
Old Dec 1, 2004 | 09:43 AM
car_boy_16's Avatar
Default Re: prelude engine code (street_ruler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">the b20a3 is the carbed 12 valve...honda used carbs on preludes till 91</TD></TR></TABLE>
Actually they stopped in 1990, you mean the 3rd generation of preludes was 1988-91, but the b20a3 was only 88-90.
Old Dec 1, 2004 | 09:45 AM
car_boy_16's Avatar
Default Re: prelude engine code (tdo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">heres some
it goes like this
'99-'01 _ USA H22A 200hp@7000RPM 156lb-ft@5250RPM DOHC 2 Yes</TD></TR></TABLE>
Those specs are off and irrelevant to this topic.
Old Dec 1, 2004 | 10:08 AM
Default Re: prelude engine code (car_boy_16)
i guess it was a 90 that i saw then
Slotz
Jan 15, 2007 07:22 PM
jmcclell
Nov 8, 2005 06:20 AM
