Need help w/ ignition switch ASAP
Old Nov 29, 2004 | 10:58 AM
AMG's Avatar
AMG
Default Need help w/ ignition switch ASAP
I know there are two parts to the ignition switch - electrical portion and mechanical portion. What is the difference and how do you know if just one or if both parts need to be replaced? When I search for an ignition switch online I can only find the electrical portion, so I'm not even sure where to get the mechanical. Does anyone know anything about this?
Thanks
Old Nov 29, 2004 | 11:47 AM
SKDRCR's Avatar
Default Re: Need help w/ ignition switch ASAP (Spooled-U)
The mechanical portion is the actual ignition cylinder.
I doubt you will need to replace that unless you jammed a screwdriver
in there or something
Old Nov 29, 2004 | 02:44 PM
AMG's Avatar
AMG
Default Re: Need help w/ ignition switch ASAP (SKDRCR)
Okay, I just wasn't too sure what exactly the mechanical portion was for. I mean nothing is broken, the key turns and the engine starts, but when I let go of the key and it turns back, the engine dies. I think its probably just the electrical part that I need to replace which is only like $50. At the place I took my car they were going to order it from Honda which included both the electrical and mechanical for like $300 plus labor, which i dont feel like paying. So i'm just gonna try to do this myself first and hope it works.
Old Nov 29, 2004 | 02:55 PM
megatron420's Avatar
i git the lock and key at napa and the electrical part at autozone spec order but mine was for 92 i guess i should of took some time and saw what your car was o well trying to help lmao
Old Nov 29, 2004 | 02:56 PM
o yea i replaced the connector part first too.... notice i said first
Old Nov 29, 2004 | 05:01 PM
ernestoG's Avatar
Default Re: Need help w/ ignition switch ASAP (megatron420)
Hey I had same problem...I had to do it twice because the one I bought after my lude was stolen did exactly what your talking about. ....
Go to the junkyard and get the whole assembly from the console. It's a pain to unbolt but not to bad (Use a screwdriver and a hammer and gently tap to loosen the bolts..
Just unplug it from the harness under the dash. I paid $35 bucks I beleive. Then put the bad boy in. It's a pain but should only take most of a saturday including running around for the stuff.
and yeah nofx rocks
DylannD
Aug 4, 2014 01:07 AM
spiffy_civic
Apr 2, 2011 12:51 AM
nfereorhatch
Jan 31, 2009 03:19 PM
