ATTS problems?
Old Nov 29, 2004 | 11:11 AM
jmar97's Avatar
Default ATTS problems?
I have a newly purchased used 5th gen '97 w/91k. My ATTS light comes on very intermitently and when it does, stays on for the duration of the drive. The car is under warranty but it does not cover the ATTS, only the engine and trans. (powertrain). And this is solely the ATTs light, not combined with the cel. I already pulled the engine diagnostic codes, but through some research have found that there are seperate atts codes, is this a dealer only thing? Also i know they recommend changing the fluid at 90k, I also know the system is very sensitive, would old fluid trigger the indicator light to go on???
Old Nov 29, 2004 | 11:14 AM
Shakes's Avatar
space cadet
Default Re: ATTS problems? (jmar97)
what code number is it?
Old Nov 29, 2004 | 11:27 AM
jmar97's Avatar
Default Re: ATTS problems? (Shakes)
sorry, i misworded that sentence. I did not have any engine diagnostic codes and I do not know how to pull the ATTS codes, thats why I asked if that was a dealer only thing?
Old Nov 29, 2004 | 11:30 AM
Shakes's Avatar
space cadet
same way as pulling the CEL. just the atts will blink instead.
Old Nov 29, 2004 | 11:34 AM
jmar97's Avatar
I originally took it to autozone bc they pull your codes for free, nothing came up then, but I was not aware of the flashing, would that appear on that diagnostic system?
Old Nov 29, 2004 | 11:37 AM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmar97 &raquo;</TD></TR><TR><TD CLASS="quote">I originally took it to autozone bc they pull your codes for free, nothing came up then, but I was not aware of the flashing, would that appear on that diagnostic system? </TD></TR></TABLE>
should. try it. im pretty sure you can pull the code that way
hondacivic97si
Jun 16, 2015 10:37 AM
93blulude
Jul 11, 2008 02:41 PM
Crippledduck51
Jan 19, 2007 01:32 PM
Spoolin'VW
15
Nov 19, 2005 03:27 PM
Voom
May 13, 2003 03:53 PM
