stripped ball joint
Old Nov 28, 2004 | 09:45 PM
dcrbin22's Avatar
Default stripped ball joint
My upper control arem ball joint stripped out , so i cant tighten the bolt. Is buying the whole arm the only option or will a shop be able to just change the ball joint ?
Old Nov 28, 2004 | 09:49 PM
hOndafienD 04's Avatar
nope, you have to buy the whole upper control arm, and it has to be right from honda....nobody else makes then
Old Nov 28, 2004 | 09:56 PM
dcrbin22's Avatar
Default Re: (hOndafienD 04)
ouch that sucks i bet its not cheap either
Old Nov 29, 2004 | 01:02 AM
littledan's Avatar
ARM, R. FR. (UPPER) NO COLOR 172.44 129.33 ... looks like it's around 130 bucks or so...
Old Nov 29, 2004 | 03:39 AM
jackstands's Avatar
Default Re: (littledan)
Northstar makes adjustable UCA's, for a little less than 100 a piece. Advance has them
Old Nov 29, 2004 | 05:36 AM
Sephro's Avatar
Default Re: (jackstands)
I have heard you can press in a new ball joint. I think it is too thin to mess with. If the ball joint is in good condition you could re-thread it....
Old Nov 29, 2004 | 08:28 AM
staticrex's Avatar
Default Re: (Sephro)
Yeah why not just re-thread it?
Old Nov 29, 2004 | 12:14 PM
lewdude's Avatar
Default Re: stripped ball joint (dcrbin22)
I have a 97 Prelude SH and there was a recall on the passengers side ball joint. I called Honda after they told me that it was bad but didn't tell me about the recall. I had to find out from another garage that I spoke with. I had Honda look up the Serial number of the car and they said "Oh yeah, there is a recall on that part". I would check that out, you might be able to get it replaced for nothing.
Old Nov 29, 2004 | 02:42 PM
chihuahuamanx's Avatar
Default Re: stripped ball joint (Chase)
i would personally go and buy the part, you'd be buying peace of mind if nothing else BUT if you have to press a ball point in it should work fine. I did it for my buddy and hes been driving stupid for over a year no problems.
Old Nov 29, 2004 | 02:53 PM
pentaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chase &raquo;</TD></TR><TR><TD CLASS="quote">I have replaced several upper ball joints on 4th gen preludes, I have no idea why there is no part # for it, but I believe one from an accord will fit if you don't want anything adjustable and want OEM quality. They press out like any other ball joint, and that 'thin' metal is pretty damn strong. Hope this saves you a few $$...</TD></TR></TABLE>
Could you find out what year and model of Accord?
Old Nov 29, 2004 | 05:06 PM
dcrbin22's Avatar
could i buy a accord upper control arm the junkyard has an accord there.
Old Nov 29, 2004 | 05:10 PM
Daboi630's Avatar
what about a upper control arm from a prelude?
pm me if you want one
Old Nov 29, 2004 | 05:15 PM
dcrbin22's Avatar
Default Re: stripped ball joint (Daboi630)
nothing around my area for a prelude. I did find one for a 1997 and one for 1991 accord anyone know if these will work ?
Old Nov 29, 2004 | 05:21 PM
fastludeh22's Avatar
how is it stripped? are the theards stripped? or when you put the nut on the stud turns?
Old Nov 29, 2004 | 05:23 PM
dcrbin22's Avatar
Default Re: stripped ball joint (fastludeh22)
stripped threads , tried putting a new bolt on but its stripped bad , maybe i can rethread it but i dont have the tools for that.
Old Nov 29, 2004 | 05:50 PM
dcrbin22's Avatar
how much do the dies go for ?
Old Nov 29, 2004 | 06:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcrbin22 &raquo;</TD></TR><TR><TD CLASS="quote">how much do the dies go for ?</TD></TR></TABLE>
2-3 dollars a piece..relatively cheap...if you can save the ball joint and not buy a whole new arm.
Old Nov 29, 2004 | 06:23 PM
dcrbin22's Avatar
Default Re: stripped ball joint (hOndafienD 04)
im not sure of the size , does anyone know ?
Old Nov 29, 2004 | 08:05 PM
prylwd's Avatar
I would just re-thread it. If you dont have the tools buy a set of dies, they are a good investment anyways. I am sure you will need them in the future.
Old Dec 9, 2004 | 02:01 AM
bad-monkey's Avatar
anyone know if the ball joint thread for EG/DC2/EK's are the same width as ones from a bb1/4/6?
looking into a project and was wondering if i could use EG compatible ball joints with our trailing arms.
G2_Fella
24
Jun 16, 2009 03:20 PM
313hitman
Mar 15, 2009 09:10 AM
dtran002
Suspension & Brakes
Nov 9, 2007 02:58 PM
staticrex
Nov 3, 2005 12:22 PM
DaChoZn1
Sep 18, 2005 03:34 PM
