throwing o2 code
Old Nov 25, 2004 | 02:10 PM
GOTNOS's Avatar
Default throwing o2 code
is my o2 faulty or did i plug the wrong connector in when i installed the swap. The connector i pluged in had a bracket attached to it. How can i tell that it is the right connector? I think my o2 is bad do to the amount of bangint around it got from shipping. But i just wanna check and make sure i have it done right. Thanks
p.s : wire color combos or pics would help if possible
Old Nov 25, 2004 | 02:31 PM
HeineKEN922's Avatar
Default Re: throwing o2 code (GOTNOS)
just fyi, i had the same problem after i did my h22a swap
first replaced it with a used o2, but still kept throwin the code...bought myself a new honda 02, and still im throwin the code
i gave up...when we hooked it up to the computer the only thing it read being out of wack was that it wasnt picking up any voltage coming from the knock sensor...
but yea..still throwing an 02 CEL
Old Nov 25, 2004 | 02:37 PM
GOTNOS's Avatar
well thats not good becuase the 02 code puts the car in limp mode that means no vtec i want vtec!
Old Nov 25, 2004 | 02:42 PM
yea but the thing is it takes a while of driving before going in limp mode...my CEL is intermittent...usually comes on after driving 30+ mins...it usually triggers it when starting and stopping a lot
i did everything...changed o2, cap, rotor, cleaned fuel injectors, replaced fuel filter
i might try swapping out my ecu..any suggestions anyone?
Old Nov 25, 2004 | 02:50 PM
GOTNOS's Avatar
Default Re: throwing o2 code (HeineKEN922)
mine comes up almost instantly.
z6hatchboy
Jul 2, 2008 07:34 PM
MysteryWagon
Mar 10, 2005 08:07 PM
denshu
Jan 11, 2004 07:46 AM
Qwikrex
Jun 22, 2002 12:52 PM
RJL
Nov 25, 2001 04:36 PM
