knock sensor
Old Nov 29, 2004 | 01:53 PM
sambam27's Avatar
Default knock sensor
i searched but i couldnt find the answer and anything about preludes.. but i blew my knock sensor. where is it located, how much are they and how to install? is it just a plug in and play? its not really a big hassle to install right...?
Old Nov 29, 2004 | 01:57 PM
AndyD's Avatar
Default Re: knock sensor (PreLudexSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreLudexSi &raquo;</TD></TR><TR><TD CLASS="quote">i searched but i couldnt find the answer and anything about preludes.. but i blew my knock sensor. where is it located, how much are they and how to install? is it just a plug in and play? its not really a big hassle to install right...?</TD></TR></TABLE>
On the back of the block, above the oil filter. It's the part at the top of the block where it joins to the head. You can't miss it.
Old Nov 29, 2004 | 01:59 PM
98TypeSH's Avatar
Default Re: knock sensor (AndyD)
I dont know about 4th gens, but on 5th gens, that thing is a freaking NIGHTMARE to get to. Gotta climb in the engine bay with your hand under the intake manifold and junk, not pretty unless you got the intake manifold off
Old Nov 29, 2004 | 02:08 PM
sambam27's Avatar
Default Re: knock sensor (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">I dont know about 4th gens, but on 5th gens, that thing is a freaking NIGHTMARE to get to. Gotta climb in the engine bay with your hand under the intake manifold and junk, not pretty unless you got the intake manifold off
damn..now i remember seeing the knock sensor. will any H-series knock sensor fit? or will i have to get a H23 knock sensor...?
Old Nov 29, 2004 | 02:11 PM
hOndafienD 04's Avatar
all h series should be the same...
Old Nov 29, 2004 | 02:16 PM
98TypeSH's Avatar
Default Re: (hOndafienD 04)
Make sure you get an OBD1 knock sensor, as the plug is round. OBD2 knock sensor are a square plug.
Old Nov 29, 2004 | 02:30 PM
megatron420's Avatar
yea i paid 113$ at honda for mine... saw one on ebay last nite for 38$$$ same one check it out
Old Nov 29, 2004 | 06:25 PM
Turbogixxer's Avatar
Old Nov 29, 2004 | 07:54 PM
Sabbotage's Avatar
Default Re: knock sensor (turbogixxer)
what sensors are #1 and #2? I've wondered what they are but never figured it out.
Old Nov 29, 2004 | 07:58 PM
Default Re: knock sensor (Sabbotage)
#1 is coolant temp for the ECU
#2 is coolant temp for your temp guage
Old Dec 1, 2004 | 09:00 PM
sambam27's Avatar
wait..can like any honda OBD1 knock sensor work in my lude? or do i have to get an H-series knock sensor?
Old Dec 5, 2004 | 03:36 PM
ItzTw's Avatar
Default Re: (PreLudexSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreLudexSi &raquo;</TD></TR><TR><TD CLASS="quote">wait..can like any honda OBD1 knock sensor work in my lude? or do i have to get an H-series knock sensor?</TD></TR></TABLE>
I'm curious too
Old Dec 5, 2004 | 03:39 PM
it might be a universal thing....bump for an anwser!
Old Dec 7, 2004 | 10:55 AM
PrettyLude's Avatar
they are different sizes
Old Dec 7, 2004 | 11:15 AM
98TypeSH's Avatar
Default Re: (PrettyLude)
im pretty dern sure that knock sensors are interchangeable. As long as you arent swapping OBD1-OBD2. Im gonna check part numbers with other honda's right now.
EDIT: the sites im checking are fookin cryptic and i cant even find the damn knock sensor.
Old Dec 7, 2004 | 12:48 PM
PrettyLude's Avatar
we tried to use a b series knock sensor in a lude, and it doesn't fit
Old Dec 7, 2004 | 12:51 PM
98TypeSH's Avatar
well then there is ur answer.
Old Dec 7, 2004 | 04:16 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">we tried to use a b series knock sensor in a lude, and it doesn't fit</TD></TR></TABLE>
any possability of making it fit or was it too small?
Old Dec 7, 2004 | 05:27 PM
turboneticst3t4's Avatar
Default Re: (prelittlelude)
don't forget proper torque! 23ft/lbs, it has been said that inproper torque can affect sensor accuracy! and of course handle sensor with care, peizo electric crysals are DELICATE!
Old Dec 8, 2004 | 08:33 PM
JDM H22's Avatar
I had a knock sensor that someone tried to souder back together and was bearly hanging on. If I hit a bump, the conection would come loose for a second and throw code. I used the sensor from a 97 si vtec civic in my 93 jdm h22. Everything is good. Hope this helps
ek-g6
Dec 30, 2007 02:21 PM
Derek88
Jun 17, 2007 03:47 PM
turbo gsr
Apr 26, 2006 03:00 PM
98civic94gsr
Jan 20, 2005 04:17 PM
smslude
Feb 19, 2003 06:24 PM
