Vacuum line sizing
Old Dec 14, 2004 | 03:06 PM
jackstands's Avatar
Default Vacuum line sizing
Will idle be affected if one were to use slightly larger vacuum lines or slightly smaller vacuum lines? Barring the obvious problem of a leak due to too large of a size. I was thinking more along the lines of vacuum volume if there's such a thing.
Old Dec 14, 2004 | 03:36 PM
Prolink's Avatar
Default Re: Vacuum line sizing (jackstands)
No, you should be fine...
Old Dec 14, 2004 | 05:32 PM
mgags7's Avatar
to what end will you be using these?
if it is some trick to increase hp i think not.....and they wont make good seal with the nipple if theyre bigger....stick to the stockers....
egmadness
Jun 7, 2006 09:34 AM
crazyimport
May 22, 2006 06:18 PM
Justin Olson
Nov 20, 2005 08:05 PM
xci_ed6
Aug 10, 2002 05:35 PM
