HID problems
Old Dec 15, 2004 | 08:10 PM
srehmat02's Avatar
Default HID problems
I installed HIDs on my lude.. but whenever I turn them on they start with a nice blue/purplish color for about 20-30 seconds and then they totally change colors to whitish/yellow.. Is this normal? If not, would it be a problem with my ballasts losing power or just my bulbs(used) are messed up?
Old Dec 15, 2004 | 08:40 PM
Odessa's Avatar
Default Re: HID problems (srehmat02)
What is the color temperature of your HID?
Old Dec 15, 2004 | 09:08 PM
PearLude98's Avatar
if you got the 4100k then your bulbs are probably still new and need time to color change and that is about 120 hours.
Old Dec 16, 2004 | 04:36 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (PearLude98)
Yes, that's normal. It's the chemicals mixing. What the temp on the bulbs? It's probably cheap bulbs.
Old Dec 16, 2004 | 08:08 AM
00LudeLover's Avatar
Default Re: (Sticky Tires)
he said they are used. so i doubt they need to be broked in.
might be too old of bulbs, or a power issue.
Old Dec 16, 2004 | 08:11 AM
* B A N N E D *
Default Re: (00LudeLover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00LudeLover &raquo;</TD></TR><TR><TD CLASS="quote">he said they are used. so i doubt they need to be broked in.
might be too old of bulbs, or a power issue.</TD></TR></TABLE>
Maybe the first owner never mixed in the chemicals correctly. You're supposed to hang them upside down for period of time.
It's too late now!
Old Dec 16, 2004 | 12:03 PM
srehmat02's Avatar
Yeah Im going to try to swap the bulbs around and see if it is a defect in the bulbs or ballasts.. because I know the bulbs have been worn in for sure..
Old Dec 16, 2004 | 12:04 PM
srehmat02's Avatar
Yeah Im going to try to swap the bulbs around and see if it is a defect in the bulbs or ballasts.. because I know the bulbs have been worn in for sure.. the color temp is 8000K i believe
rainmanef
Lighting
Jul 10, 2008 05:26 PM
intgraCA
Jan 2, 2007 10:55 PM
ThaReal24k
Apr 28, 2005 08:11 PM
freezerburnv2
Mar 18, 2004 02:39 PM
slowacura
Nov 18, 2003 06:57 AM
