Pulleys
Old Dec 16, 2004 | 04:54 AM
WtPanther's Avatar
Default Pulleys
What exactly is the deal with aftermarket lightweight pulley sets?? im hearing so many different things about them. For example, in my Jeg's magazine, it states that the AEM lightweight pulleys will add an approximate 20 or so hp. Then i talk to people about it and they tell me different stories like they only add 5 to 10 hp. Please explain to me what i should believe??
Old Dec 16, 2004 | 07:03 AM
Dougs96SI's Avatar
Default Re: Pulleys (WtPanther)
Depends on the type of pulleys you are buying. If you are talking about the AEM power pulleys, those will give you about 5 hp max. The entire purpose of those is to put a bigger pulley in place of the small alternator pulley that it comes stock with, which will give the pulley slower and longer turns which will take some powere away from your electronics, which will free up a little power in your engine.-- If you have an aftermarket sound system without a capicitor, you need to buy a capacitor in order for you system to function without draining your battery.
Old Dec 16, 2004 | 08:08 AM
TypeR0207's Avatar
Default Re: Pulleys (Dougs96SI)
1-3 whp if you are lucky with the underdrive pullies ........... you gain almost nothing from pullies.
This is from dyno testing on my Type R, I dynoed every mod I put on the car. The pullies gave me no more than 1-2 across the board, no actual peak horsepower difference.
Old Dec 16, 2004 | 10:54 PM
PrettyLude's Avatar
its not even worth the money i find, i had a set of aems on my lude, the damn alternator pulley was crap, it was not producing enough current at idle to where it drained my batter at idle
Old Dec 17, 2004 | 06:15 AM
WtPanther's Avatar
Default Re: (PrettyLude)
k, so im kinda gettin the vibe.. not to get the pulleys???
Old Dec 17, 2004 | 06:56 AM
TypeR0207's Avatar
Default Re: (WtPanther)
Pretty much. I picked up mine for the Prelude used for $80, so it will be worth it for me maybe. But to go out and spend $175 new makes no sense imo.
mattf22b1
Apr 9, 2006 07:57 PM
austincrx
May 16, 2005 06:23 PM
SL!M
Apr 30, 2003 07:22 AM
JungleJ
Jan 27, 2003 07:05 PM
o_Rage_o
Jan 16, 2002 08:39 PM
