h22a head
Old Dec 14, 2004 | 02:58 PM
redlude04's Avatar
Default h22a head
So im real close to buying a jdm head for my h23 block.But just a couple of things crossed my mind a h23 block is obviously a bigger bore than the 2.2 so more fluid will be comming up from the block and then being crammed into the head which is smaller is that a problem, I can get it bored bigger if i need too. Im assuming i will need a new wirring harness for the head and a h22a ecu is that correct. If anyone has the h22 head on the h23 block and will like to share there thoughts about it would be greatly appreciated.
Old Dec 14, 2004 | 03:36 PM
Prolink's Avatar
Default Re: h22a head (redlude04)
Have youu tried searching this topic? I believe there are many, many of them..
Old Dec 14, 2004 | 04:19 PM
redlude04's Avatar
Default Re: h22a head (Prolink)
yes i have tried but have found nothing on the diffrent size on the bores and i figured why not put in the other stuff while im at it.
Old Dec 14, 2004 | 04:44 PM
v4lu3s's Avatar
RTFM
um...how is an 87mm bore different from an 87mm bore?
next time search for h23vtec its all over teh damn place.
Old Dec 14, 2004 | 04:46 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlude04 &raquo;</TD></TR><TR><TD CLASS="quote">So im real close to buying a jdm head for my h23 block.But just a couple of things crossed my mind a h23 block is obviously a bigger bore than the 2.2 so more fluid will be comming up from the block and then being crammed into the head which is smaller is that a problem, I can get it bored bigger if i need too. Im assuming i will need a new wirring harness for the head and a h22a ecu is that correct. If anyone has the h22 head on the h23 block and will like to share there thoughts about it would be greatly appreciated.</TD></TR></TABLE>
ha 'obviously'
h23 and H22 blocks are the same bore.
Displacement has 2 variables: bore and stroke. you now have one eliminated. good luck figuring it out
Old Dec 14, 2004 | 04:56 PM
EGmikeH22's Avatar
* B A N N E D *
p0wn3d
kornerk12
Feb 4, 2007 10:14 PM
independnt1
Apr 22, 2004 06:44 AM
gulf imports
Jul 14, 2003 01:22 PM
92-h23a1
May 29, 2003 04:39 AM
VRD^don
Jan 29, 2003 02:35 PM
