95 Prelude VTEC threw Engine Code - help!
Old Dec 11, 2004 | 06:15 PM
Import RP's Avatar
Default 95 Prelude VTEC threw Engine Code - help!
Hey guys, I've got a 95 Prelude VTEC. Today my check engine light came on - so I checked the service connector and it threw code #12. This is the Exhaust Gas Recirculation (EGR) code. The car seems to be running fine though... just wondering if anyone else has had this code thrown and what the remedy would be. Any info would be greatly appreciated!
Thanks guys,
Jeff
Old Dec 11, 2004 | 11:13 PM
vtecludeh22's Avatar
Default Re: 95 Prelude VTEC threw Engine Code - help! (Import RP)
welll it only has to do with the egr valve on your intake manifold, so just check and make sure the vacume line is conected on both ends, and the same with the electric plug!
Old Dec 12, 2004 | 01:19 AM
SKDRCR's Avatar
Default Re: 95 Prelude VTEC threw Engine Code - help! (vtecludeh22)
Try disconnecting the negative battery cable
for about 5 or 10 minutes.
Then reattach it and start your car, see if the code is still there.
Old Dec 12, 2004 | 07:24 AM
thehondaguru's Avatar
Default Re: 95 Prelude VTEC threw Engine Code - help! (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">Try disconnecting the negative battery cable
Then reattach it and start your car, see if the code is still there.</TD></TR></TABLE>
And if it is still there pull the egr off the im and claean the **** out of it with carb cleaner.
Old Dec 12, 2004 | 08:03 AM
hOndafienD 04's Avatar
i wouldnt bother cleaning it, unless you gotta pass smog....mines disconected.....your car will not run bad with bad egr..
Old Dec 12, 2004 | 10:58 AM
mgags7's Avatar
or you could leave it on and clean it
just get a little straw thing on your carb clean bottle and spray under where you can reach through to the diaphragm....spray it good, then work the diaphragm up and down for like 10 minutes....spraying every like 30 seconds....
that should free it up, or you could plunder one from your archives of Import Replacement Parts...
when youre done disconnect the battery for 30 secs.....lets the ecu reset
Old Dec 12, 2004 | 11:55 PM
Import RP's Avatar
Default Re: (mgags7)
Thanks for all the help guys, sounds like a pretty miner problem. I appreciate the feedback!
Best Regards,
Jeff
azmal3125
Nov 21, 2017 10:05 AM
turbulance25m
Audio / Security / Video
Sep 13, 2005 08:14 PM
Import RP
Dec 14, 2004 10:06 PM
accord2nv
Oct 12, 2004 05:55 PM
thehondaguru
Nov 23, 2003 07:38 AM
