Problem need opinions
Old Dec 13, 2004 | 08:21 PM
dcrbin22's Avatar
Default Problem need opinions
ive noticed recently my car sort of wobbles , its worse when slowing down kind of feels like the back wheel is bent but its fine. It feel like its from the rear end and it shakes pretty bad on the highway.
Old Dec 14, 2004 | 05:03 PM
Prolink's Avatar
Default Re: Problem need opinions (dcrbin22)
First your title sucks.... Are you hearing any noises? Have you checked tire pressure? When is the last time wheels were balanced? Have you checked the lug nuts?You should jack the car up and test for any freeplay in the wheel when you move it up and down. If there is freeplay, wheel bearings are bad.
Old Dec 14, 2004 | 05:07 PM
$300lude's Avatar
Run your hands around your tires to feel for any "hills" or other abnormal wear.
Old Dec 14, 2004 | 05:12 PM
mgags7's Avatar
firstly, the title needs to be more specific....this board is made to answer problems, specifics help
there are many possibities here:
1)your wheel bearings might be bad
2)tires might have a shifted belt, like 300 said, run your hand over them and feel for bumps....
3)they might be terribly out of balance, or seriously needing alignment, have that looked at
4)maybe loose lugs or low pressure like prolink said....
as for when you hit the brakes, that means you have warped rotors, either get new ones, or take these off and have them cut......
Old Dec 14, 2004 | 05:17 PM
dcrbin22's Avatar
Default Re: (mgags7)
Yeah sorry about the tiltle I checked everything out , my tires in the rear have bad wear on the inside. The cars lowered. probaly a shifted belt seeing that they are worn down really far in like an 1/2 inch wide area. Thanks for the replys. Anyone have any suggestions for some decent all seasons for the stock si wheels.
Old Dec 14, 2004 | 05:24 PM
mgags7's Avatar
im driving on a set of kumho 732 touring tires that came on my friends car right now, i like them a lot
they defy the kumho name.... they actually are lasting fairly well.....
Old Dec 14, 2004 | 05:38 PM
dcrbin22's Avatar
Default Re: (Chase)
Its not really low , i have neuspeed sports that came with it , but your right it would be a waste to buy new tires and just wear them out. who makes a a good camber kit ?
Old Dec 14, 2004 | 05:40 PM
mgags7's Avatar
lol chase.....nobody even thinks of the word "camber" anymore.....all they think is "sLaMmEd!!" haha
definitely get some camber kits and a good alignment before you chew up more tires.....
Old Dec 15, 2004 | 06:46 PM
dcrbin22's Avatar
Default Re: (Chase)
Yeah thats what im thinking I was even thinking of raising it to stock. It does feel pretty bad. Its does not feel right.
valox138
Sep 29, 2008 09:11 AM
JBirch_97Prelude
Dec 3, 2007 09:22 PM
Krnbk2
May 12, 2003 09:03 PM
grngsr01
May 8, 2003 01:53 PM
TurBoXBirD16
20
Jun 6, 2002 04:13 PM
