tach off
Old Dec 11, 2004 | 10:54 PM
esca's Avatar
Default tach off
my tachometer is off... its above by 200 when its idle.. it idles at 1k, and it normally idles at 700-800, but i know its idling around 700-800 because it doesnt sound like 1k, and on the highway, my 5th gear usually 83-85 mph is 4k rpm for me, but now its 3.7k rpm
i still hit vtec at the right times, but when i look at the tach, it hits at 4.8 instead of 5.2, but the engine sounds like its at 5.2
and as i increase how fast im going... the worse it becomes, like.. im going 100 but my tach shoes 4.5k rpms
does anyone know how to fix this problem? it just startedn happening tonight..
Old Dec 12, 2004 | 08:09 AM
DarkBB4's Avatar
Default Re: tach off (esca)
How do you know this (i.e VAFC? REV/speed/ aftermarket Tach?)
How old is the car?
Its been proven that some older cars the tachometers are off alittle bit... If u have a vafc orrev speed you can get the EXACT number nad its MUCH more accurate because its through the ECU
Old Dec 12, 2004 | 09:13 AM
The Birdman's Avatar
Default Re: tach off (DarkspeedVtec95)
All honda tachs are off. Yours is just bein a little more wierd than normal. Nothing to be alarmed about. Also if you watched your tach before it started messin up you would see that vtec seems to kick in at a different rpm in each gear. Its just the tach, if you want the real numbers you would need a rev/speed meter or vafc. NO WORRIES, ITS ALL GOOD
Old Dec 12, 2004 | 05:03 PM
esca's Avatar
Default Re: tach off (jd3jdm)
sickkk.. heheh.. just making sure
another to H-T
yeah.. i just got a job.. so that vafc is coming one step closer.. probably this weekend infact.. i cant wait
terribl3jon
Jan 26, 2006 06:00 PM
SuperSlowH22
Oct 25, 2005 04:43 PM
94h22a
Sep 5, 2005 08:41 PM
TypeSH
Jul 30, 2002 10:33 AM
1fastGSR
Nov 25, 2001 06:14 PM
