Heat Problems:
Old Dec 14, 2004 | 04:41 PM
DarkBB4's Avatar
Default Heat Problems:
Hey well winters coming along and My heat does not work. AC does not blow MAD cold, but the fans are blowing.. and Air is Shooting out.
the Plug in my firewall Seems to be intact but im not sure.
WHat other things can i trouble shoot?
rear defrost works
front takes a LONG *** time
Old Dec 14, 2004 | 04:45 PM
Hawkze_2.3's Avatar
Default Re: Heat Problems: (DarkspeedVtec95)
Make sure the slider that chooses hot/cold is connected and actually opening/closing what it's supposed to. You can see where it connects right behind the IM on the firewall...
Old Dec 14, 2004 | 05:00 PM
DarkBB4's Avatar
Default Re: Heat Problems: (Hawkze_2.3)
well i haven tcheckd that..b ut one thing is that it Doesnt go all the way to the cold/hot side.. kinda jammed
Old Dec 14, 2004 | 05:03 PM
Hawkze_2.3's Avatar
Well, that's probably what's wrong is that for some reason the selector is not going where it needs to. Check the thing on the firewall, and then pull out your climate control box and you'll probably see the problem
Old Dec 14, 2004 | 05:04 PM
$300lude's Avatar
may be the heater core.
Old Dec 14, 2004 | 05:08 PM
mgags7's Avatar
probably not the heater core.....you definitely have a problem with the slider and cable.....
its funny how many of these posts are popping up now that were freezing our asses off.....do you guys never move the slider the rest of the year, or were you just too lazy to fix it then and now youre shivering.....
Old Dec 14, 2004 | 05:33 PM
$300lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkspeedVtec95 &raquo;</TD></TR><TR><TD CLASS="quote">well i haven tcheckd that..b ut one thing is that it Doesnt go all the way to the cold/hot side.. kinda jammed</TD></TR></TABLE>
Dang, I didn't see that.
Old Dec 14, 2004 | 06:07 PM
DarkBB4's Avatar
Default Re: Heat Problems: ($300lude)
OK
WHERE IS THIS THIGN ON MY FIREWALL
PICS WOULD HELP
sorry for the caps btw
im gonna rip out my climate control but what is the proper way to do it
I DONT Hav ea helms
Old Dec 14, 2004 | 08:41 PM
jmar97's Avatar
Default Re: Heat Problems: (Chase)
I just had the same problem and fixed it, sort of, anyway. My cables were all out of whack so i just disconnected the one going to the firewall under the glove and manually opened the heater valve inside the engine bay on the fire wall to the position that lets the coolant circulate and I am good to go. I had to take a long pole and just pushed it to the correct position..
Old Dec 14, 2004 | 09:05 PM
leonard1818's Avatar
Default Re: Heat Problems: (jmar97)
Funny, i had a similar problem. when i would slide the hot/cold over to hot, it would spring back over to cold as if it were spring loaded. After taking apart the whole climate control to "adjust the cables" i found out that it was just that i needed to spray some WD-40 on the heater valve in the engine bay.... it had been stuck open and just needed a little lube. anyway, 2 hours of my life were spent taking apart something that ended up being a 10 second fix... i dont know if this is your problem but for any people who may have the same problem with winter coming up, check that first.
Old Dec 14, 2004 | 10:04 PM
PrettyLude's Avatar
Default Re: Heat Problems: (leonard1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chase &raquo;</TD></TR><TR><TD CLASS="quote">I bet the cable has slipped on the bottom of your climate control unit. Its held in place with a screw with a big washer on it. I have seen it happen and when it does it wont let you go all the way to cold. Remove the radio and look @ the bottom of the CC, you'll see it. I just replaced my cable with a new one.....it's sooo smother now </TD></TR></TABLE>
Old Dec 14, 2004 | 10:16 PM
SiB16A's Avatar
Default Re: Heat Problems: (PrettyLude)
i'm having the same problem. My defrost works, but nothing else. Not even the side mirrors. I found out it was my fuse box...no power was going to some of the fuses. no idea why...or how it broke.
cornsnake19
Nov 28, 2017 09:11 PM
GraphiteMW
Aug 17, 2007 05:51 AM
ekferio
Nov 3, 2006 06:12 AM
92SleeperH23
Apr 11, 2005 10:15 AM
bigslimdog
16
Jan 27, 2004 02:51 PM
