Rear brake problem
Old Feb 2, 2005 | 05:24 PM
lyric911's Avatar
Default Rear brake problem
Ok, I feel like a damn retard, but I cannot for the life of me remove my rear calipers (1994 VTEC). Help?
Old Feb 2, 2005 | 07:47 PM
lyric911's Avatar
Default Re: Rear brake problem (lyric911)
Bump?
Old Feb 2, 2005 | 08:02 PM
homesauce's Avatar
You rotated the 4 pronged thing back so the caliper can clear it right?
Old Feb 2, 2005 | 08:26 PM
diewX3's Avatar
Default Re: Rear brake problem (homesauce)
Use a rubber mallet to remove the caliper off the rotor. For pushing the piston back in there's a tool for it. It connects to a ratchet and pushes the piston back in
Old Feb 2, 2005 | 08:38 PM
SKDRCR's Avatar
Default Re: Rear brake problem (diewX3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diewX3 &raquo;</TD></TR><TR><TD CLASS="quote">Use a rubber mallet to remove the caliper off the rotor. For pushing the piston back in there's a tool for it. It connects to a ratchet and pushes the piston back in </TD></TR></TABLE>
You don't need a special tool, just find a rubber scraper or something flat to turn it.
The piston should turn fairly easily
As far as the caliper istelf, there's only a couple bolts that connect it to the spindle itself.
Just take a better look at it
Old Feb 2, 2005 | 08:43 PM
SKDRCR's Avatar
Default Re: Rear brake problem (SKDRCR)
Maybe this pic will help you out a little
Old Feb 2, 2005 | 09:02 PM
lyric911's Avatar
Ok, that pic helps a lot. I had both bolts removed, its evidently just stuck.
Wait, the rear caliper has stuff attached to the back of it (IT appears to be parking brake stuff) that isn't in that pic. Do i still only need to remove the two bolts though?
Modified by lyric911 at 10:13 PM 2/2/2005
Old Feb 2, 2005 | 09:22 PM
SKDRCR's Avatar
Are you just replacing pads?
If so, it should only be 2 bolts to remove the caliper itself.
Use a flathead screwdriver or something to pry it away from
the rotor.
Old Feb 2, 2005 | 09:23 PM
PrettyLude's Avatar
yes you need to remove the two bolts
Old Feb 2, 2005 | 09:58 PM
lyric911's Avatar
Default Re: (PrettyLude)
I swear I'm not usually this retarded. I had those two bolts out (like every other car I've done this too) but the caliper wouldn't move. Didn't want to risk damage, so I thought I'd find out for sure before I screwed anything up. Thanks guys.
Fo-Do Fanatic
May 6, 2007 08:04 PM
ibe2fly
32
Jul 7, 2005 04:09 PM
urbanlegend21
Sep 7, 2004 11:01 AM
_jester_
14
Nov 26, 2003 04:55 AM
Egone
26
Oct 2, 2003 01:59 PM
