VTEC POINTs....
If your car is stock, leave it at the stock engagement point. Honda knew what they were doing when they set it where it is. Dyno it test some settings if you want it earlier but if your stock, leave it stock. just my opinion...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If your car is stock, leave it at the stock engagement point. Honda knew what they were doing when they set it where it is. Dyno it test some settings if you want it earlier but if your stock, leave it stock. just my opinion...</TD></TR></TABLE>
Its there for a reason, that and the fact that no normal person wants to be in vtec in 5th gear when there crusing at higher speeds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NZludedude »</TD></TR><TR><TD CLASS="quote">So where agreed at 5200. Is this on both gen's.
no only on 5th gens.
4th gen is 4900
4th gen is 4900
4900 is 4th gens andi really have no experience with 5th gens so i couldnt tell you. although in 4th gens it looks like 5200 because of the inaccuaracy of the manual guage.
Modified by enigma94 at 8:23 PM 2/2/2005
Vtec is engaged at 4938 and disengaged at 4750 in a high load situation,
and it is engaged at 6313 and disengaged at 6188 in a low load situation. In a stock P13 ecu..I know this for a fact..From looking at the code..
The best point to set your vtec crossover is were your power curves cross on a duno. If you don't know then leave it stock..
Modified by MindEracer at 2:06 AM 2/4/2005
Frank_and_Beans
14
May 21, 2008 06:44 AM
