lost
Old Jan 29, 2005 | 11:56 AM
polishprinze's Avatar
Default lost
i was pritty sure i bent my vavles i had down shifted from 3 into 2 and my car jumped to probley about 8500 rpm. it died on me as soon as i got to a stop light then started back up and did that pritty much every time i stoped but was fine when i was moving. i took it up to a shop and my number 3 cylender was at like 140 and he said i probably bent some valves. i took my head off and brought it back up to them and they said it looks like there fine. so what do i do next could it b my piston rings or did the vavles just need to b ajusted
Old Jan 29, 2005 | 12:53 PM
Hawkze_2.3's Avatar
Default Re: lost (polishprinze)
Try doing a valve adjustment, and if that doesn't fix it, then take it somewhere else and have them look at the valves. I give it a 90% chance that you did bend some valves....
Old Jan 29, 2005 | 01:18 PM
Default Re: lost (Hawkze_2.3)
yeah me to but that means im gonna have to put it back on to do the valve ajustment and then take it back off it ive bent some valves. is there anyway i can check them my self
Old Jan 29, 2005 | 08:14 PM
Prolink's Avatar
What were the results of the other cylinders? 140psi your car should still run. Variance between the cylinders should not be more that 29PSI. How do the pistons look?
Old Jan 30, 2005 | 12:45 PM
Default Re: lost (Prolink)
i was in the 200s i think and my pistons look fine. my car ran its just sometimes it would die when i would stop they said i probaly bent only 2 valves or so but when i took the head to them the said they were fine.
Old Jan 31, 2005 | 05:03 AM
anyone else have any incite
Old Jan 31, 2005 | 07:52 AM
CarpAngler's Avatar
Did you check stupid things also like vacum lines and what not. In my lude i had bent all 8 exhuast valves. The car would shut off when i stopped and ran extremely rough. I still managed to drive the car 20 miles home.
I would be willing to bet on bent valves. Have you delt with the shop before that you took it to.
Old Jan 31, 2005 | 12:21 PM
Default Re: (lude975)
well not me but my friend with a 98 sh did. he did the same thing as me and they said the same thing .he had them do some port work and then they told him the valves were bent. the reason i took my car there is they have delt with only hondas and acuras for 20 years and he was vary saticfied with the work they did. i assumed that they just made a mistake with the valves.
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
civicmitch
Apr 27, 2009 02:07 PM
EH3forlife
12
Jan 20, 2008 07:55 PM
smokey2.0
Dec 27, 2003 05:18 AM
