Cleaning the Engine Bay
Old Jan 30, 2005 | 12:22 PM
K-Spec's Avatar
Default Cleaning the Engine Bay
Hey
i want to clean my engine bay and was wondering if i need any special type of chemical? Which ones I should use and not use? And do i have to cover anything, alternator, fuse box, hid ballasts, etc?
Old Jan 30, 2005 | 12:35 PM
clemsoncb7's Avatar
Default Re: Cleaning the Engine Bay (khalal538)
Damn man, lemme tell you to be very careful. Cover ALL ELECTRICAL **** including the distributer because I forgot to and got a little water underneath the cap, I lost cylinder #3 for more than a week! I would suggest some elbow grease and a towel, no water.
Old Jan 30, 2005 | 12:36 PM
Dougs96SI's Avatar
I hand-wash mine with a wet micro-fiber rag. Looks good, but takes hours.
Old Jan 30, 2005 | 12:40 PM
five-0's Avatar
Default Re: Cleaning the Engine Bay (Dougs96SI)
I usually do a quick spray and then do the rest by hand. Works fine. Just stay away from the distributor like mentioned before. Clean that ****. There is nothing worse tha a dirty motor.
Old Jan 30, 2005 | 01:15 PM
K-Spec's Avatar
Default Re: Cleaning the Engine Bay (five-0)
what spray do you use?
Old Jan 30, 2005 | 01:26 PM
OaksRacing's Avatar
I have cleaned my engines for years guys. Either Simple green if your doing it in a residential area or 2-3 cans of engine gunk. Spray under the hood under the engine, battery, fire wall - everything except the distributer - some people put aluminum foil around their distributor. If you using a high pressure hose like at a car wash just don't be dumb - keep the pressure tip at least 2 - 3 ft away from everything. Make sure your block is cooled off and wash off any that may have gotten onto your fenders or anywhere else on the paint.
Start the engine when finished and let it dry off from the heat. Good luck.
Steve Sr.
Old Jan 30, 2005 | 01:27 PM
ViZ's Avatar
ViZ
i saturate it with simple green, use very little water to rinse, and lots of rags and elbow grease.. I also put bags over all the elctronics and tape them of real good (ie fuse box and distributor.. and i also unhook the battery just to be safe, let it dry dont start right away and if you can use an air compressor and a blower attachment to blow out water around the spare plugs and distributor
Old Jan 30, 2005 | 01:38 PM
five-0's Avatar
I work at a dealership and use a product simply known as "Engine shine". I was talking with the detail guy and I was like..."so let me get this straight, you put this on your engine and it makes it shine hugh?" He said "hells ya!", and I've been using it ever since. LOL... who knows what it really is.
Cleaning by hand yeilds the best results.
Old Jan 30, 2005 | 01:43 PM
92hondalude's Avatar
i use rag tooth brush and Q-tips
big.turbo.daddy
Detailing
May 16, 2014 12:28 PM
2000SICVC
Paint and Body
14
Jan 7, 2012 01:40 PM
megalomaniac001
Honda S2000
Apr 2, 2008 11:40 AM
isaldjgxi
Jul 29, 2004 11:43 AM
X2BOARD
Jul 29, 2002 01:24 PM
