tranny problem please help
Old Jan 29, 2005 | 12:03 PM
silvr92lude's Avatar
Default tranny problem please help
hey i have a 92 h23 lude. i have been noticing that it is very hard to put it into 3rd gear. now today i got in it and i couldnt even put it into reverse then i tried 1st also didnt work. if you know if my clutch is fried or what is wrong please help me out
Old Jan 29, 2005 | 08:16 PM
Prolink's Avatar
Default Re: tranny problem please help (silvr92lude)
How does the clutch feel? Have you checked the clutch fluid? Can you shift gears when the car is not running?
Old Jan 30, 2005 | 09:54 AM
AndyD's Avatar
When you have difficulty putting it into gear, can you do it if you turn the car off??
Old Jan 30, 2005 | 01:18 PM
chrisgags13's Avatar
First, do you have a short throw shifter? Like one of those dc deals ( little adaptor)
Take it out, its junk. If you did have it in, they mess up syncros and **** around with the gears lining up, so you might be up the creek. But your problem sounds like the cables or something theyre connected to is messed up. Look over the shift system closely. Also check your clutch system: slave cylinder, master cylinder, lines, and fluid. After that is done and the problem is still there then go to a tranny shop and ask them to diagnose it. If theres a problem inside it might be cheaper to just buy a new tranny. Or find a friend thats good with them, and lots of beer and food to give him. Good Luck.
Old Jan 30, 2005 | 04:04 PM
VM 2's Avatar
Default Re: tranny problem please help (chrisgags13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgags13 &raquo;</TD></TR><TR><TD CLASS="quote">First, do you have a short throw shifter? Like one of those dc deals ( little adaptor)
Take it out, its junk. If you did have it in, they mess up syncros and **** around with the gears lining up, so you might be up the creek. </TD></TR></TABLE>
Where have you heard that short shifters screw up your synchros and such? Or do you know from experience? please explain in further detail
YangFlavor
Transmission & Drivetrain
Apr 14, 2009 07:24 PM
islandhonda
Jun 1, 2007 09:02 AM
mchuang
Mar 9, 2004 05:14 AM
ludelvr
Oct 4, 2003 05:38 PM
HavokB18
Jul 26, 2003 05:32 PM
