need help with head removal
Old Jan 27, 2005 | 03:36 PM
Btothe3rdDegree's Avatar
Default need help with head removal
hey guys, i am helping a friend remove his head from his h23 and we cant get the pasenger side nut that holds the intake and head together, i cant even see it!! any easy way to get ti off?
Old Jan 27, 2005 | 03:45 PM
mgags7's Avatar
get the stuff out of the way and use a wrench.....
make sure you guys follow the head bolt loosening sequence....
edit: why are you even taking the intake off....just leave it on and pull it with the head....
Old Jan 27, 2005 | 03:51 PM
Akhany's Avatar
Default Re: need help with head removal (Btothe3rdDegree)
Yeah, I would just pull the intake out with the head.
The first time i took out my head, I took the intake off first, and it was a BIOTCH.
Space is too damned tight, much easier to pull intake out with it.
Old Jan 27, 2005 | 06:30 PM
Default Re: need help with head removal (Akhany)
well i thought it would be easier because i didnt want to disconnect all tose damn lines and connections! so it is easier to leave the intake mani on? is there a support on the mani to the chasis? (i know civics have em)
Old Jan 27, 2005 | 08:01 PM
PrettyLude's Avatar
on the h22 i know there is a brace from the bottom of the intake manifold to the block, not too sure about the h23 though, but yeah its easier to leave intake manifold on with head
Old Jan 27, 2005 | 10:37 PM
SKDRCR's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">on the h22 i know there is a brace from the bottom of the intake manifold to the block, not too sure about the h23 though, but yeah its easier to leave intake manifold on with head</TD></TR></TABLE>
wurd.
Unless you have some crazy pimp *** tool, you're gonna have to remove the camshafts
to gain access to the head bolts.
Make sure you unbolt them in sequence 1/3 turn at a time.
Don't forget about the bracket that bolts the im to the block
or the water pipe that has to be disconnected.
Old Jan 28, 2005 | 11:32 AM
LudeyKrus's Avatar
Just remove the intake w/ the head; trust me.
It's much easier to figure out how to hook up the vacuum hoses than to try to get that bastard intake manifold back on w/ the motor in the car!
TouringAccord
Nov 23, 2005 09:10 AM
Benjithx
Dec 3, 2004 11:05 AM
DeeJay
Mar 11, 2003 09:24 AM
integra6650
Jul 21, 2002 05:40 PM
