compression at 9:1 ratio
Old Mar 31, 2005 | 09:20 AM
Quade's Avatar
Default compression at 9:1 ratio
What should my compression be at a 9:1 compression ratio? Using JE pistons. Stock H22A1 otherwise.
Old Mar 31, 2005 | 09:36 AM
95PreludeSi's Avatar
Default Re: compression at 9:1 ratio (Quade)
9:1? Is this a trick?
I think you may need to re-word your question
Old Mar 31, 2005 | 09:41 AM
Greyout's Avatar
Default Re: compression at 9:1 ratio (95PreludeSi)
I think he is wondering what his compression test results will yield.
I would guess the results would vary directly with the compression ratio of the piston...
so maybe a 9:1 would give you 90% of whatever stock results are? which is like 200, right? so 180? I dunno
Old Mar 31, 2005 | 09:43 AM
Default Re: compression at 9:1 ratio (Greyout)
oh, my bad.
Old Mar 31, 2005 | 10:12 AM
eMpAtHy's Avatar
im supposed to be at 9:1 but my numbers were like 230 across the board....
Old Apr 5, 2005 | 02:24 PM
eMpAtHy's Avatar
Default Re: compression at 9:1 ratio (eMpAtHy)
ttt
Old Apr 5, 2005 | 03:01 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">What should my compression be at a 9:1 compression ratio? Using JE pistons. Stock H22A1 otherwise.</TD></TR></TABLE>
Wouldn't the non-frm-compatible pistons destroy the frm sleeves?
Old Apr 5, 2005 | 03:12 PM
eMpAtHy's Avatar
Default Re: compression at 9:1 ratio (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't the non-frm-compatible pistons destroy the frm sleeves?</TD></TR></TABLE>
i dont know, but for 9:1 compression, is 230 a little high?
ochsy03
Apr 4, 2005 05:04 PM
B20luda
Jun 8, 2004 08:20 PM
avex
Apr 23, 2004 08:34 AM
3sixtycrew
Dec 6, 2003 10:13 PM
JDM 007
Jan 24, 2003 01:08 PM
