Question about Engine Swapping
Old Mar 31, 2005 | 05:26 PM
J_Lude07's Avatar
Default Question about Engine Swapping
Im thinkin bout swapping my h23a for a h22a, can i use the h23a tranny, axles, and ecu and still use the h22a. And do you guys think a 30 day warranty on a engine is long enough?
Old Mar 31, 2005 | 05:41 PM
mgags7's Avatar
i think a startup warranty is fine.....buy from a reputable company and you wont have to worry about that....
the more warranty the better, but you are better off spending a bit more and being safe....
Old Mar 31, 2005 | 05:45 PM
Shakes's Avatar
space cadet
Default Re: (mgags7)
go with either
http://www.importautosalvage.com
or
http://www.hmotorsonline.com
and you wont go wrong.
you will need to use the H22 ECU as well as possibly wire your car for VTEC. search. there are probably a hundred + threads on this alone.
Old Apr 1, 2005 | 01:29 AM
95greenlude's Avatar
Default Re: (Shakes)
i'm not going to doubt a ht guru, but i thought the h23 ecu was ok to use with a h22, just have to run 2 wires, to the vtec solenoid, and something else i forgot .....will check tomorrow.......or is h23 p14? ah hell i'll just wait till the morning to check
Old Apr 1, 2005 | 08:52 AM
J_Lude07's Avatar
so have you found out whether i can or not...cuz ive been lookin and i aint gettin no luck with h23a h22 swap...i think h23a is p13..ill check
Old Apr 1, 2005 | 08:55 AM
SKDRCR's Avatar
Default Re: (J_Lude07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">i'm not going to doubt a ht guru, but i thought the h23 ecu was ok to use with a h22, just have to run 2 wires, to the vtec solenoid, and something else i forgot .....will check tomorrow.......or is h23 p14? ah hell i'll just wait till the morning to check </TD></TR></TABLE>
The h23 uses the p14 ecu and I strongly advise against using the p14
on an h22a. The fuel maps are different and will lean out your motor.
Old Apr 1, 2005 | 08:57 AM
SKDRCR's Avatar
Default Re: (SKDRCR)
BTW: You can get the complete package (motor, tranny, ecu)
from HMO for a good price.
Old Apr 1, 2005 | 09:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for clarifying that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">BTW: You can get the complete package (motor, tranny, ecu)
from HMO for a good price.</TD></TR></TABLE>
hell yea, i was looking last night, their damn cheap
Trident9
Jul 16, 2010 11:12 AM
OzWolfbane
Mar 2, 2005 04:37 AM
Blanket Jackson
Nov 17, 2004 09:12 AM
Mixdmixd
May 6, 2004 04:07 PM
H22TurboNos
Jun 22, 2002 07:27 AM
