water pump replacement
Old Sep 13, 2005 | 12:40 AM
twistedbydezign's Avatar
Default water pump replacement
ok it seemed obvious, but the helms did not say if u have to drain the coolant when replacing the water pump, so do u have to drain or no???
thanks
Old Sep 13, 2005 | 02:20 AM
onefastrx7turbo's Avatar
Default Re: water pump replacement (buffalo wings)
definetly have to drain coolant.
neil
Old Sep 13, 2005 | 10:01 AM
andre809_lude's Avatar
yes u do have to drain the coolant, if you dont it will poor all over you when u take the pump out. You'll have some coolant that will poor out even if you'll drain the radiator, but this way the pump spill will be easier to clean up, then all the coolant out of the radiatot.
gud luk
Old Sep 13, 2005 | 10:19 AM
Default Re: water pump replacement (andre809_lude)
i thought so, wonder why helms left it out, also, it says to put RTV sealant around the wp gasket, is RTV the same as hondabond???
Old Sep 13, 2005 | 10:24 AM
yup. RTV = Hondabond
neil
91akira
Jan 31, 2014 07:36 AM
justint7121
Nov 21, 2010 09:46 PM
spaceman
Apr 21, 2004 06:17 AM
raene
Mar 1, 2003 05:06 PM
Spartanic
Jan 1, 2002 04:46 AM
